Page 2 of 3 1 2 3
Re: too much cam????? kinda long-please help!!!!! [Re: 70challenger408] #723426
06/13/10 10:18 PM
06/13/10 10:18 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
not that it's your problem or a contributing factor but unless i missed it you make no mention of valve springs and/or changing them to accommodate a roller cam.
Re: too much cam????? kinda long-please help!!!!! [Re: MR_P_BODY] #723427
06/13/10 10:26 PM
06/13/10 10:26 PM
Hemiroid Offline
Hemiroid  Offline
Not really too hard to figure out. You have a 3800# car with a small block, a big open plenum single plane, a set of 3.55 gears, relatively low compression with aluminum heads. The cam hasn't been degreed and who knows what else hasn't been done?
I'd start by degreeing the cam, and then changing the rear gear. As Mr.P mentioned, has a stall test been done on the converter? Putting a little more arm in a small block doesn't turn it into a big block. You may have gotten away with these things with a stroked BB, but not with a small block. I'm sure with a little tuning and changing a few things it will perform like you want it to. Just be patient, it will come around.
Re: too much cam????? kinda long-please help!!!!! [Re: MR_P_BODY] #723428
06/13/10 10:27 PM
06/13/10 10:27 PM
ill
dennismopar73 Offline
ill
never seen a comp cam way off
run several checked all with degree wheel
i always check mine
i have seen one that was WAY out there wasnt a comp ,,
used to be a guy live here who worked at comp
learned alot about cams from him done alot of work with the ss guys back in the day
more problems with gears and chains than any cams by the way
Re: too much cam????? kinda long-please help!!!!! [Re: dennismopar73] #723429
06/13/10 10:35 PM
06/13/10 10:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
i always check mine
I had one that the key way in the cam was cut 29*
off so if you lined up the dots it CRASHED big time,
without degreeing the cam it CANT BE SAID its straight
up or not... of course you can guess all you want
Re: too much cam????? kinda long-please help!!!!! [Re: dennismopar73] #723430
06/13/10 11:55 PM
06/13/10 11:55 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I have... the one I just pulled out of my Challenger's engine had to be installed +8 on the gear set to actually end up +3 on the ICL (i.e. 5 degrees retarded).
I installed & mapped the profiles of that Comp, an UltraDyne, a Bullet and a Lazer in my engine while it was still on the stand and the ONLY cam that was ground correctly as far as "straight up" phasing was the Lazer. The Bullet was the worst and the the Comp and the UltraDyne were about equally off, but in opposite directions.
Moral: DEGREE IT.
Re: too much cam????? kinda long-please help!!!!! [Re: jamesc] #723431
06/13/10 11:58 PM
06/13/10 11:58 PM
las vegas
70challenger408 Offline OP
las vegas
yes springs were replaced with matching springs recommended by COMP.
here are the 1/4 info you requested mr p-body
r/t-.656
60'-2.123
330-5.88
1/8-8.99
mph-79.30
1000-11.6876
et-13.98
mph-98.07
can't find previous best slip, but i know it was 12.7 @105mph
I was foot braking it-launch @3000rpm, small wheel spin, and shifted at 6500rpm-trapped at 6800rpm(if I remember right).
any useful thoughts????
Re: too much cam????? kinda long-please help!!!!! [Re: MR_P_BODY] #723432
06/14/10 12:21 AM
06/14/10 12:21 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
If he is running pump gas the plugs could be white so he may not be lean.
I have that same cam in my street car. .030 over 440 11.1 with MW ported indy SR heads and ported indy DP intake, 3.55 gear with 2.77 first gear set. My tank weights 3900 lbs. I think the reason that cam works well in my combo is the DP intake.
Re: too much cam????? kinda long-please help!!!!! [Re: 70challenger408] #723433
06/14/10 12:27 AM
06/14/10 12:27 AM
WA
JD Dart Offline
JD Dart  Offline
WA
So with you foot braking it, it will hold at 3000 rpm without moving the car? From the time slip it looks real lazy make sure you get that cam degree like every one has said I've put a number of those cams in even with a 3800 stall they would 60' 1.5's in a Dakota truck.
best so far 8.53 @ 158.59 MPH 60'1.240
Re: too much cam????? kinda long-please help!!!!! [Re: Darryls-Demon] #723434
06/14/10 12:28 AM
06/14/10 12:28 AM
las vegas
las vegas
mr p body
Re: too much cam????? kinda long-please help!!!!! [Re: 70challenger408] #723435
06/14/10 12:34 AM
06/14/10 12:34 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
couple of questions...
what time of year was that you ran it compared to this year...the vegas heat can slow a car down almost .5 tenths...
I have all the tools necessary to degree in a cam...except it is more of a PIA with heads on..
Tony
70 AARCuda Vitamin C
Re: too much cam????? kinda long-please help!!!!! [Re: 70AARcuda] #723436
06/14/10 01:03 AM
06/14/10 01:03 AM
las vegas
las vegas
I ran it at midnight mayhem 1 month ago-temps were in mid 70's that night.
scott
Re: too much cam????? kinda long-please help!!!!! [Re: 70challenger408] #723437
06/14/10 07:48 AM
06/14/10 07:48 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
et-13.98
mph-98.07
What size tire? 6800 rpm @ 98 mph, I'd be looking at my converter or transmission. BYW it should be very strong with that cam .
Re: too much cam????? kinda long-please help!!!!! [Re: 70challenger408] #723438
06/14/10 08:37 AM
06/14/10 08:37 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I'd really like to know what intake you took off......I'd guess a Performer or similar?
What I see is you went 2 different directions with the car......
Single plane intake on an engine that probably makes peak power at 5300 RPM.
Cam is bigger, probably not detrimental to the combination but, not degreeing
it in is a BIG no no.
Then you went from 3.91 to a 3.55 gear........2 directions this case.
I would attribute .5 second to not spending time tuning at the track.
I'm not going to bust you up but, you changed the engine to move the power
up in RPM and the rear end to lower it.
That's just what I'm seeing.
Re: too much cam????? kinda long-please help!!!!! [Re: S/ST 3040] #723439
06/14/10 09:16 AM
06/14/10 09:16 AM
las vegas
las vegas
3.55's were installed last summer when I made the 12.7 pass. so is the general census change oput the gears???? if so, what gear set????? also, going back to the plugs, were should the color on the ground strap start for a good burn??? in answer to earlier questions, i made 3 passes with current combo-13.9 waas the best
also, intake taken off was a wieand stealth open plenum.
Re: too much cam????? kinda long-please help!!!!! [Re: 70challenger408] #723440
06/14/10 10:12 AM
06/14/10 10:12 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Something is WAY off there. I have the same cam in a very similar combo…410 stroker, 10.8 comp, ported eddys, Air-gap, 750dp, 4.10 gear…only mine runs 6.90’s @ 98mph in the 1/8 with a 1.49 60’. In the heat (90°F with lots-O-humidity) my car only slowed to a 7.08 @ 97mph. This cam make a lot of torque, so I doubt your gears are hurting you that much.
IMO, if you used the spring recommended by comp (914-16) then that may be part of your problem right there…those springs are too light. I’m running comp 939-16 installed @ 1.85, which gives ~ 190 lbs on the seat & ~460 lbs open. You should probably use more spring than what I have, I’m just limited due to my rockers.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: too much cam????? kinda long-please help!!!!! [Re: 70challenger408] #723441
06/14/10 10:16 AM
06/14/10 10:16 AM
gregsdart Offline
gregsdart  Offline
The first thing you need to do is find out if all cylinders are sealing, and the cranking compression. If the cranking compression is even, follow with a leak down test. You want good ring seal or all else is a waste of time.
Theses steps well tell the story of roughly where the cam is, and if the wiped lobes took out the rings.
Next, find a way to check the air fuel ratio. You need to know if you are anywhere close. Jet as needed.
I highly recommend a chassis dyno session to be certain your ignition and fuel ratio get dialed in and have no problems.
Next, test the converter to see just how high it will flash once the motor is up and running strong. If your converter will flash past torque peak, the gears will have significantly less impact. If you have too little stall, they will kill you.
Too little stall to me with this combo would mean anything less than about 4400+ rpm.
If you get stuck anywhere along the line diagnosing this, just stay at looking for a way to get the info you need. Without doing this step by step, you are just stabbing in the dark.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: too much cam????? kinda long-please help!!!!! [Re: 70challenger408] #723442
06/14/10 10:20 AM
06/14/10 10:20 AM
MR_P_BODY Offline
MR_P_BODY  Offline
r/t-.656
60'-2.123
330-5.88
1/8-8.99
mph-79.30
1000-11.6876
et-13.98
mph-98.07
Looks like most of the problem is the low end...
like its lacking torque to get it rolling... I would
degree the cam in FIRST and add a few degrees of
advance for the heavy car... also seems like a lot
of rpm for your gear
Re: too much cam????? kinda long-please help!!!!! [Re: gregsdart] #723443
06/14/10 10:28 AM
06/14/10 10:28 AM
gregsdart Offline
gregsdart  Offline
Using a cam/running compression calculator, you should have about 200 pounds cranking compression if the cam is set at 104 degrees. That will run on 93 octane, or should. The dual plane might very well be a better choice here as well, as most don't loose ground to a single plane intake till after 5000 rpm. Remember that a LOT of time is required to get past 5000 rpm after the launch, and on each gear change. That is why a real loose converter is needed for a single plane.
Re: too much cam????? kinda long-please help!!!!! [Re: 70challenger408] #723444
06/14/10 11:10 AM
06/14/10 11:10 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
My gut tells me the cam is retarded when extra advance would get you going. From the 1/8 to 1/4 it pulled pretty good.
At 6700 I would assume you were still in second gear
98 would be about the right speed with 3.55 gears and a 27 inch tire.
OR you have 50% converter slip?? or you were trapping at 4600??
Re: too much cam????? kinda long-please help!!!!! [Re: 70challenger408] #723445
06/14/10 11:12 AM
06/14/10 11:12 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
r/t-.656
60'-2.123
330-5.88
1/8-8.99
mph-79.30
1000-11.6876
et-13.98
mph-98.07
Forget about the engine for now. Something is terribly wrong in the trans or converter. 6800 rpm with 3.55 gears and 26" tires(what I would concider small for that car) should be going almost 150 mph. At 98 mph you should be under 5000 rpm. Big time slippage somewhere.
Page 2 of 3 1 2 3
