Park cable for a 63 plymouth. #723125
06/13/10 05:08 PM
06/13/10 05:08 PM
NY
X
XXHEMI Offline OP
XXHEMI  Offline OP
X
NY
Can any one tell me if the park cable for a 63 Plymouth and Dodge are the same???
Pulled one out of a Dodge and it seems to be about 2" short in my Plymouth. I also change the tail shaft to a 65 would that have anything to do with it?
Any help would greatly be appreciated. Trying to get this thing out for the next F.A.S.T races in two weeks.
Thanks Ed
Re: Park cable for a 63 plymouth. [Re: XXHEMI] #723126
06/13/10 05:22 PM
06/13/10 05:22 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Looking in A&A Transmission's 2010 catalog, it shows one part number
for the park cable, fitting 1962-65 A, B, C bodies and Imperials.
Hope that helps.
Re: Park cable for a 63 plymouth. [Re: S/ST 3040] #723127
06/13/10 05:30 PM
06/13/10 05:30 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Hope that helps.
That must be a "universal" type cable that is long enough to fit all applications. My original suspicion is probably correct that they are different. Imperial Services shows a different cable-Dodge vs, Plymouth.
MB
Re: Park cable for a 63 plymouth. [Re: XXHEMI] #723128
06/13/10 10:04 PM
06/13/10 10:04 PM
Pa.
62max Offline
62max  Offline
Pa.
Checked my 63 parts manual and they are different. 63 Plymouth is 2401291, Dodge is 2401292
Re: Park cable for a 63 plymouth. [Re: 62max] #723129
06/13/10 10:15 PM
06/13/10 10:15 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
...from the different position of the shifter IN and NEAR the dash itself ? .. IMO ....what a waste !! ......
And YET MaMopar dropped the drain-plug in the trans-pan for a MASSIVE savings of 25 cents ??... !!
I will bet the cable-diff/cost-diff was more-than-that !!
Re: Park cable for a 63 plymouth. [Re: dOc !] #723130
06/14/10 07:09 AM
06/14/10 07:09 AM
NY
X
XXHEMI Offline OP
XXHEMI  Offline OP
X
NY
Next big question does anyone have one??
I have been told the repops are not as good as the originals? Any opinions?
Thanks Ed
845-548-9000
Re: Park cable for a 63 plymouth. [Re: dOc !] #723131
06/14/10 03:45 PM
06/14/10 03:45 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Or they dropped the drain plug so that you have to remove the pan to drain it, the thinking was that if you have to pull the pan you're more likely to change the filter and adust the rear band.
Re: Park cable for a 63 plymouth. [Re: XXHEMI] #723132
06/14/10 06:13 PM
06/14/10 06:13 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Thanks Ed
845-548-9000
Hi Ed, I left you a voicemail. LMK if you still need one
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
