Doug's Headers OR ? for mild build 440?
#722961
06/13/10 12:25 PM
06/13/10 12:25 PM
Posts: 115 Tampa Bay
BadFishy
Tampa Bay
I've been reading the various header posts and like the idea of Doug's ceramic coated, but am concerned that they might be too much for my mild build 440. From what I can find, they are only available in 2". I have a street cruiser 71 Cuda, 727, stock heads with 3 angle, 650 cfm Eddy Thunder, Speed Pro CS-1148R cam. (That cam is 224/224 and 455/455.) From what I have been reading, it looks like I should be going with 1 3/4" tubes. I have HP manifolds, but want to switch for that SOUND! Is there any way to go with the 2" tubes with the 3" collectors, and use a 2 1/2" exhaust system set-up? Or will that create other problems as a result? TTI has a 1 3/4" but they are another couple hundred $. Any thoughts on how I can use the Doug's? Or based on my set-up, any other good quality brand recommendations? I only put about 1,000 miles per year on the car and only want to do this once! Thanks a lot.
1971 Cuda, 440 custom-build
Re: Doug's Headers OR ? for mild build 440?
[Re: BadFishy]
#722962
06/13/10 12:34 PM
06/13/10 12:34 PM
Posts: 565 IA
landon1
IA
i just have the street hedmans on mine, which are alright and install is easier than with 2". wish i would've had money for ceramic coated ones, the elite hedmans are still 1.75/3", but with the ceramic coating for $350...on my wish list
'71 Satellite Sebring 440
Re: chico
[Re: Kudakidd]
#722964
06/13/10 07:49 PM
06/13/10 07:49 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I'd go 1-7/8, I used the hookers on a car before 5903 or something like that was the part number. I had to do a little clearancing, but nothing major. This was with manual steering and a mini starter. I also have used the 2" hedmans, which had slip flip tubes and are very easy to installed. Although they need even more clearancing than the hookers did.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
