Re: 440 pistons 120 in the hole
[Re: Magnum]
#722305
06/13/10 11:49 PM
06/13/10 11:49 PM
Posts: 779 Washougal,Wa
Dodge
Washougal,Wa
How far down are 69-70 pistons? .060?
Stand behind your word
[Re: quickd100]
#722307
06/14/10 07:04 PM
06/14/10 07:04 PM
Posts: 4,333 Prospect, PA
BSB67
Prospect, PA
You'd want a set of 68-69 pistons. Mine were .050 in the hole. Dave
Can you still get them?
[Re: BSB67]
#722308
06/14/10 07:30 PM
06/14/10 07:30 PM
Posts: 75,280 A gulag near you.
JohnRR
A gulag near you.
I haven't seen a direct replacement 68-69 piston EVER , and .050 is too far in the hole still . Buy a 2.065 CH piston.
[Re: JohnRR]
#722309
06/14/10 10:19 PM
06/14/10 10:19 PM
BSB67
Prospect, PA
I have a set of forged replacements, but they are pretty old. With the deck trued, they we about 0.039". Blue printed I think they are about 0.027". You'd need to cut the deck more to get a decent quench with a closed chamber head.
[Re: BSB67]
#722310
06/14/10 10:45 PM
06/14/10 10:45 PM
Dodge
Washougal,Wa
How far down in the hole are 71 stock 440 pistons?
[Re: BSB67]
#722311
06/15/10 05:38 AM
06/15/10 05:38 AM
JohnRR
A gulag near you.
That must be a very old piston then because since I started paying attention to these thing within the last decade that piston has not existed in the aftermarket.
Or just buy the 6pk replacement piston with the 2.065 CH and square the deck . Your BLUEPRINT spec is an NHRA number , ACTUAL factory blueprint is closer to the actual .050 in the hole .
[Re: Dodge]
#722312
06/15/10 05:41 AM
06/15/10 05:41 AM
JohnRR
A gulag near you.
HP or 6pk ?
Either way don't go building back to factory spec , they didn't have a clue what they were doing back then except for the HEMI
What head are you using , I think I missed that ?
[Re: JohnRR]
#722313
06/15/10 07:29 AM
06/15/10 07:29 AM
Dodge
Washougal,Wa
A set of 906 heads came with the engine. Thanks Terry
[Re: JohnRR]
#722316
06/15/10 07:29 PM
06/15/10 07:29 PM
BSB67
Prospect, PA
Of course. It was implied and I presumed that everyone would understand.
The pistons were part number L2286. I purchased them in 1990.
[Re: DaytonaTurbo]
#722318
06/15/10 09:38 PM
06/15/10 09:38 PM
Dodge
Washougal,Wa
Just trying to use what I have for now and have another 440 on the engine stand for a later time or car. I've never driven my charger. It has a 383 in it now and I should've had the 440 in and driving 3 years ago. I'm getting pretty slow at making non runners drivers these days. I will probably use what I have for now and put this engine in. Its been raining up here like crazy for the last 2.5 months and its already the middle on June. Thanks Terry
[Re: Dodge]
#722319
06/17/10 09:31 PM
06/17/10 09:31 PM
Dodge
Washougal,Wa
Anybody have a 71 440 sitting around with the heads off? Can you tell me how far below the deck the pistons are? Thanks Terry
[Re: Dodge]
#722320
06/17/10 09:54 PM
06/17/10 09:54 PM
Posts: 10,303 Someplace you aren't
SomeCarGuy
If I had a good engine and the the only problem i had was the pistons were that far down, it wouldn't stop me from running it. it won't run as good as a high comp engine, but it will still provide many miles of fun for no extra money or effort.
I want my fair share
[Re: Dodge]
#722322
06/18/10 03:22 PM
06/18/10 03:22 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
Well, this is what I don't get. My engine is out of a 71 Newport, a 4bbl, dual exhaust engine. Took the heads off a few years ago and measured the pistons with a straight edge and a feeler gauge. That's all I had. Pistons measured 0.020 on one side and 0.025 on the other side, in the hole.
[Re: Dodge]
#722323
06/18/10 03:28 PM
06/18/10 03:28 PM
Posts: 1,196 imperial mo.
stickman
imperial mo.
Back in the 80`s I had a 70 challenger with a stock 440 that it came with from the factory. I put the lower compression pistons in it due to lower octane gas. It did reduce low in power but was still a very fun car to drive. If you got it & don`t want to spent any more money. Put it in & let her eat. Have some fun.
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
