upper control arm bushings #722010
06/11/10 11:18 PM
06/11/10 11:18 PM
mo
ALKYW5DART Offline OP
mo
the upper control arm bushings is it better to use the rubber or poly ones? it is strictly a race car thanks
Re: upper control arm bushings [Re: ALKYW5DART] #722011
06/12/10 01:18 AM
06/12/10 01:18 AM
Boise
Moparteacher Offline
Boise
Depends on the type of race car. Drag race? Use rubber.
Circle or road race use poly.
Re: upper control arm bushings [Re: Moparteacher] #722012
06/12/10 02:49 PM
06/12/10 02:49 PM
mo
mo
YES DRAG RACE ONLY, WHY IS RUBBER BETTER THEN POLY. SHOULD I USE RUBBER LOWER CONTROL ARM BUSHINBG TOO
Re: upper control arm bushings [Re: ALKYW5DART] #722013
06/12/10 03:10 PM
06/12/10 03:10 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Yes. The poly is too stiff and slows down the action needed for transfer.
JAKES AUTOMOTIVE
