best way to mount a cross flow radiator #720985
06/10/10 11:10 PM
06/10/10 11:10 PM
iowa
rook440 Offline OP
rook440  Offline OP
iowa
what is the best way to mount a cross flow aluminum radiator in an A body ,,pictures of your install are appreciated/.....
Re: best way to mount a cross flow radiator [Re: rook440] #720986
06/11/10 12:15 AM
06/11/10 12:15 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I took my Griffin to a radiator shop and had brackets welded to the top and bottom. I secured the radiator with 4 bolts.
Re: best way to mount a cross flow radiator [Re: Kern Dog] #720987
06/11/10 12:44 AM
06/11/10 12:44 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
These are slightly modified Ford brackets, mid 80s sedan. I used the same ones on the bottom.
Re: best way to mount a cross flow radiator [Re: Jim_Lusk] #720988
06/11/10 01:35 AM
06/11/10 01:35 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
better to isolate the aluminum rad in place instead of directly bolting it in.
I made brackets for the Belvedere but I should hit the yard and look at some of those for the Demon.
Re: best way to mount a cross flow radiator [Re: nomore65BelvJim] #720989
06/11/10 11:04 AM
06/11/10 11:04 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I should add that the ones on the bottom are welded to the lower rad support. For the top brackets I cut off the part that bolted to the Ford rad support and drilled a hole for the bolt and welded that to the bracket.
Re: best way to mount a cross flow radiator [Re: Jim_Lusk] #720990
06/16/10 09:34 PM
06/16/10 09:34 PM
iowa
rook440 Offline OP
rook440  Offline OP
iowa
Re: best way to mount a cross flow radiator [Re: rook440] #720991
06/17/10 09:30 AM
06/17/10 09:30 AM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
side flows belong in Chevys!
