tunnel ram scoops/aircleaner assembly #720503
06/10/10 11:48 AM
06/10/10 11:48 AM
Saskatoon,Saskatchewan. Canada
HEMIBERT588 Offline OP
does anyone know of any nice tunnel ram scoops, i have a dual dominator setup on a sheet metal intake and a hood with a scoop is not going to work at all. i do however want to run air cleaners or a scoop of some style. any ideas??
Re: tunnel ram scoops/aircleaner assembly [Re: HEMIBERT588] #720504
06/10/10 12:11 PM
06/10/10 12:11 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
dont know if there is any dominatorsized K&N velositystacks with filters on them but i know they made a pretty big differens on a friends smallblockcar compared to those tiny 6" aircleaners it used to have wich i the same size as those that fit in the typical blowerscoops.
Re: tunnel ram scoops/aircleaner assembly [Re: HEMIBERT588] #720505
06/10/10 03:58 PM
06/10/10 03:58 PM
I run the K&N ten inch(maybe nine inch diameter) by six inch tall filters on my twin Dominator tunnel ram motor I hope they fit into my tunnel ram hood scoop, I have not ran that motor in the car yet EDIT, The air cleaners are K&N 9x5 with the nine inch extreme tops, see the picture attached. I called K&N tech to see how much filter area I needed for the 527 C.I. motor with two 1050 carbs, the 9x5 are suppose to be 1/3 bigger than needed with two carbs excluding the extreme tops
Re: tunnel ram scoops/aircleaner assembly [Re: Cab_Burge] #720506
06/10/10 07:52 PM
06/10/10 07:52 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
their is a pair of 1050,s under there
(one on the right)
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
