Firm Feels on the way #718275
06/07/10 01:01 PM
06/07/10 01:01 PM
Detroit
HogRidinFool Offline OP
Detroit
Never changed a gear box before. Anything I need to know? I do have a pitman arm puller. so I'm good there. Service manual says to drop the column...Do I realy to do that? Also, best way to get the couple pin out...Thanks
2010 Mopar 10 #000-500
Re: Firm Feels on the way [Re: HogRidinFool] #718276
06/07/10 01:53 PM
06/07/10 01:53 PM
Santa Barbara, CA
HitIt Offline
HitIt  Offline
Santa Barbara, CA
You can probably loosen the column and pull it to the rear to free the coupler, but you might just be able to remove the piman arm and frame bolts and pry it loose from the steering coupler.
I'm sure others will answer, but the thing I would say is definitely use plenty of loctite on the box to frame bolts. Those things have a way of working themselves loose, which can be dangerous.
Re: Firm Feels on the way [Re: HitIt] #718277
06/08/10 08:27 AM
06/08/10 08:27 AM
Detroit
Detroit
Re: Firm Feels on the way [Re: HogRidinFool] #718278
06/08/10 03:23 PM
06/08/10 03:23 PM
Ottawa, ontario
dd340 Offline
dd340  Offline
Ottawa, ontario
I just swapped mine power sterring box to a manual. It is not complicated but it sure is a beast to work on it. I found the 3 bolts that hold the box in place a real pain to get at and even worse to get back in, I didn't have much room to work and it was done under the car. Try to get the car raised as much as possible. The other thing that you will almost certainly need to do is unbolt the motor mounts and jack the motor up on the drivers side to give it more clearance to get the box in and out. I would also take out the battery and tray out to give more room to take out the box.
Re: Firm Feels on the way [Re: dd340] #718279
06/08/10 09:46 PM
06/08/10 09:46 PM
NJ
440challenger Offline
NJ
just did in an ebody. Have to pull the column (why wouldnt you anyway,takes all of five minutes)
I did it with the motor out, looks liek it would be a nasty job with a big block and supercomp headers
Re: Firm Feels on the way [Re: 440challenger] #718280
06/08/10 11:57 PM
06/08/10 11:57 PM
CA
mojavered Offline
mojavered  Offline
CA
I just put one in my 71 Challenger with a 440 in it. I did not have my headers on, it was a breeze. Not sure how it would go with headers on?
71 Challenger RT
440 / 727 / 8.75
Re: Firm Feels on the way [Re: 440challenger] #718281
06/09/10 10:54 AM
06/09/10 10:54 AM
Detroit
Detroit
Thanks to all for the insite...Looks like a fun job (especially on jack stands).
Is there a secret to getting the pin out of the coupler or is it as easy as knocking it out with a hammer & drift?
Re: Firm Feels on the way [Re: HogRidinFool] #718282
06/09/10 10:58 AM
06/09/10 10:58 AM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
I went to Sears and got a set of roll-pin punches and it went pretty well. Love my Firm Feel stage 2, that's for sure.
Darren
Re: Firm Feels on the way [Re: HogRidinFool] #718283
06/09/10 12:07 PM
06/09/10 12:07 PM
Westchester, NY
JM67RT Offline
JM67RT  Offline
Westchester, NY
The box can get kinda heavy when you're trying to get it in place while on your back. I've done it on two cars and one thing I did on the second car that helped was I got an extra bolt the same as one of the mounting bolts and cut the head off. I then used this as a locating dowel to get the box in place. I put the remaining two bolts in then switched the dowel for the last bolt. Made the install a whole lot easier IMO.
Re: Firm Feels on the way [Re: JM67RT] #718284
06/10/10 01:10 PM
06/10/10 01:10 PM
Detroit
Detroit
The gear just showed up....You anit lying when you said it's "kinda" heavy!
Thanks all for the input!
Re: Firm Feels on the way [Re: JM67RT] #718285
06/10/10 01:50 PM
06/10/10 01:50 PM
OK
David_Trimble Offline
OK
I just replaced my box, and rather than take the risk of it slipping out of my hand and onto my head while installing it from under the car, I loosely tied a rope to it and had someone 'topside' help haul it into position while I maneuvered it into place and got the bolts in...
David
'69 Dodge Charger R/T
