GOOD YEAR DRAG SLICKS??? #717705
06/06/10 02:42 PM
06/06/10 02:42 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Does anyone use Goodyear bias-ply slicks in a D-3 compound? How do you like them? I've got a set coming in this week that I got a good deal on,brand new! Should improve my 1.56-1.58 60' times! What kind of pressures are you using on your heavier cars? The GTX w/driver weighs 3740 lbs. Thanks fella's! RandyB
Re: GOOD YEAR DRAG SLICKS??? [Re: Labratt] #717706
06/06/10 04:11 PM
06/06/10 04:11 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Mine are a D-5 compound and I love them. I'm a little lighter than you are though and I think you made a good choice going with the D-3 based on what I've read about thier compounds.
Re: GOOD YEAR DRAG SLICKS??? [Re: WILD BILL] #717707
06/06/10 07:49 PM
06/06/10 07:49 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks Billy! "I'm a LITTLE lighter than you" That's an understatement!!!
Re: GOOD YEAR DRAG SLICKS??? [Re: Labratt] #717708
06/06/10 07:59 PM
06/06/10 07:59 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I could use to loose a little weight on mine
Re: GOOD YEAR DRAG SLICKS??? [Re: WILD BILL] #717709
06/06/10 08:01 PM
06/06/10 08:01 PM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
what size tires????
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: GOOD YEAR DRAG SLICKS??? [Re: StripeHOG] #717710
06/06/10 08:08 PM
06/06/10 08:08 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Mine or Randy's?
Re: GOOD YEAR DRAG SLICKS??? [Re: StripeHOG] #717711
06/06/10 11:18 PM
06/06/10 11:18 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Andrew,29"x 9" Old ones are 30"x 9"! I don't think 1" will make much difference in rpm's at the stripe! So...no one else runs a D-3 compound out there???
383man [Re: Labratt] #717712
06/07/10 12:08 AM
06/07/10 12:08 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Cant help you Randy but I do use 30 x 9 Hoosier radial slicks. They do work nice and I love how well the radial slick handles on the top end. Ron
Re: 383man [Re: 383man] #717713
06/07/10 01:10 AM
06/07/10 01:10 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
I hear ya Ron! The one's I just wore out were Good Year Radials,which I really liked,as well,because of the top-end stability! I just couldn't get them at a comparable price to the bias-ply! The new one's will be $125.00 each. Pretty fair price!
Re: 383man [Re: Labratt] #717714
06/07/10 01:18 AM
06/07/10 01:18 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Always liked my Goodyears on the Cuda. They worked very well and never really went away much over the long term.
I recently made the switch to M/T and we will see what happens with them. So far so good. I did go quicker in the 60' than ever with them, but they are stiff sidewall and my GY's were not. I went to M/T becuase of the deal I got from M/T on the them, not becuase there were any issues with the Goodyears. I still have them with 30 passes on them.
Re: 383man [Re: Al_Alguire] #717715
06/07/10 01:48 AM
06/07/10 01:48 AM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
I'd start at 13.5-14 and work your way up till it spin's I run a 28x11.5 and run as much as 15 on a cool day if needed (I adjust rear tires for reaction time) and my car probably weigh's in at 3300-3400 w/ me..... low air pressure does nothing but kill the sidewall's and slow you down!!! my car will hook on anything....if I'm in the grove LOL
Re: 383man [Re: StripeHOG] #717716
06/09/10 03:04 PM
06/09/10 03:04 PM
Kissimmee, Florida
aarlucas Offline
aarlucas  Offline
Kissimmee, Florida
My car is as heavy as yours. I used these slicks and they have been the best set I have tried to date. They hook forever, or mine did anyway. I ran between 14 and 15 psi in mine.
Re: 383man [Re: Al_Alguire] #717717
06/09/10 07:16 PM
06/09/10 07:16 PM
WA
JD Dart Offline
JD Dart  Offline
WA
I'm using the M/T too with 107 passes they only have .009 wear looks like they will make it for this season N/P. How does your car drive when you come off the stop mine feels like it's doing the duck walk. Around 1000' starts to settle down
Re: 383man [Re: JD Dart] #717718
06/09/10 09:16 PM
06/09/10 09:16 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I was curious about the shelf life of Goodyear slicks. The 34 roadster I bought has a set of Goodyear 14.5 x 32's that look almost new but I know they are at least 5 years old. Whatcha guys think? I think I'm going to at least try them.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: 383man [Re: 69dart] #717719
06/09/10 10:19 PM
06/09/10 10:19 PM
nc
moeflo Offline
moeflo  Offline
nc
Not sure about the shelf life. On an earlier car (3200 lbs) the wear-hole meant something. On the last car (2400 lbs) the bite would go away and the wear holes were still very deep. This happened with G-Y, M/T and Hoosiers. The compound was gone before the rubber on the lighter car. Makes me skittish of used ones.
Re: 383man [Re: 69dart] #717720
06/09/10 10:38 PM
06/09/10 10:38 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i can only tell you my personal experience. the sig car was purchased new and sat for MANY years because i got involved in racing bikes. then i finished the car ran it with a chevy that broke. then i sat again, i finally built an engine for it and ran it. the tires had to be over ten years old probably closer to 15 so i figured they just HAD to be bad. brought a new set of tires, made absolutely no difference.
