Post deleted by Defbob
[Re: rowin4]
#717226
06/05/10 11:10 PM
06/05/10 11:10 PM
Re: ATI Super Damper users ?
#717227
06/05/10 11:13 PM
06/05/10 11:13 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Yep I think I ended up with a 1 1/4 long bolt but it was a hair to long.. Its a standard NF thread Russ, and should be available at your local harware store. I simply used a Grade 8 Bolt with some Blue locktite. When you going to have that beast ready?
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Moparnut426]
#717231
06/06/10 10:31 AM
06/06/10 10:31 AM
You have to change to the longer bolt. Mancini Racing carries it.
[Re: B G Racing]
#717236
06/07/10 02:29 PM
06/07/10 02:29 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
We have a selection of grade 8 bolts with varying lengths for different dampners and cranks.We install the dampener in each application and measure the depth of the crank bolt hole to the face of the dampner register.We select the bolt and washer combo that will give us a minimum of the bolt diameter in thread engagement or more but careful not to bottom out the bolt or pull the thread from the crank.
Thanks for both Andy's and Bob's explanation on the crank bolt on the ATI dampner. But....I have a crankshaft that was new 41 runs ago. And the reason I don't build my own motors anymore, is because I spend too much on parts to make a mistake and ruin these parts in the middle of the season, and I can't afford to replace them right now. It's not that I am looking to blame someone, but I paid a reputable builder to assemble this engine 41 runs ago. And I have a hard time blaming him when 2 other reputable builders used the same bolt with the same dampner prior to this guy building this engine. For some reason, this time it came loose. I am not sure, now that it has the longer bolt, that it will not rattle loose again because of the chatter marks on the cranshaft and dampner. So, that's why I don't know where to turn to fix this, or if the longer bolt will keep things in tact. You can't blame ATI because it should have been checked. And you can't blame the builder because that's the way it came. It's just frustrating to me every time this type of thing happens.
[Re: camastomcat]
#717237
06/07/10 03:10 PM
06/07/10 03:10 PM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
So.....I just had this very issue and now the end of my crankshaft is a messed up along with my ATI balancer hub. I may need to pull the motor to fix it in the middle of the season. And all ATI says is buy another bolt?
I understand what you are saying but ----- your engine builder should have checked this before just putting it together. That is the reason I asked this question in the first place... I checked it and it didn't look right so I inquired about it and now I have the answer and will get the right bolt. And yes it would have been easier if they would have told me when I ordered it that I needed to use a longer bolt or for a couple $$$ more just add it in with the damper.
Russ
[Re: camastomcat]
#717238
06/07/10 03:11 PM
06/07/10 03:11 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
But a good experienced builder would have made the correction.
