clutch fan #714503
06/02/10 08:30 PM
06/02/10 08:30 PM
Vermont
BLACKLINELAYER Offline OP
Vermont
I was wonder what any of you have had for good or bad on using a stock type clutch fan in your cars. I took my car out of storage recently and while driving it home it overheated on me. I have a flex type fan in it now have always thought I was kind of pushing it with that fan as the car was originally set up for the 1/4 mile but, now I want to be able to drive it for a longer period of time. Hoping to pick your brains. It is a 71 Demon with a mild 440
Post deleted by Defbob [Re: BLACKLINELAYER] #714504
06/02/10 08:34 PM
06/02/10 08:34 PM
Re: clutch fan #714505
06/02/10 08:41 PM
06/02/10 08:41 PM
Vermont
Vermont
what year HHR?
thanks
Re: clutch fan [Re: BLACKLINELAYER] #714506
06/02/10 09:07 PM
06/02/10 09:07 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
If the car overheated at highway speeds, its not the fan, its the radiator or cooling system in general.
I used to run my Duster (440) with 3.91 gears, and it had a electric fan on it. At anything above 40 mph I would simply just turn the fan off.
It should never run hot at highway speeds
Re: clutch fan [Re: BLACKLINELAYER] #714507
06/02/10 09:12 PM
06/02/10 09:12 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Maybe you should ask in the question and answer section too. It is asked about twice a week so it is in the tech forum
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=5492771&Main=5415648
Or you can do a search
http://www.google.com/custom?domains=boa...RID:1&hl=en
http://www.google.com/custom?hl=en&c...ard.moparts.org
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Post deleted by Defbob [Re: BLACKLINELAYER] #714508
06/02/10 09:15 PM
06/02/10 09:15 PM
Re: clutch fan [Re: Bob_Coomer] #714509
06/02/10 09:19 PM
06/02/10 09:19 PM
mi usa
O
old yeller Offline
old yeller  Offline
O
mi usa
ARE YOU SERIOUS?..What planet you live on?
Re: clutch fan #714510
06/02/10 09:20 PM
06/02/10 09:20 PM
Lehigh Acres, Florida
rickstershemi Offline
Have you ck'd to make sure your bottom hose isn't sucking closed....?????
Rickster
Re: clutch fan [Re: rickstershemi] #714511
06/02/10 09:27 PM
06/02/10 09:27 PM
Vermont
Vermont
Rickster
yes, I have springs in both upper and lower good thought though thanks
Re: clutch fan [Re: rickstershemi] #714512
06/02/10 09:27 PM
06/02/10 09:27 PM
Bad Axe,MI
E
EDDIEB Offline
EDDIEB  Offline
E
Bad Axe,MI
Is it running lean?
EDDIE B
Re: clutch fan [Re: old yeller] #714513
06/02/10 11:03 PM
06/02/10 11:03 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Its obvious You and I live in diff planets.
Its funny you question me cause I heard you look like a vagrant, and even have the proper smell...LOL
Anyways
I have seen many cars have heating problems and people want to blame the fan..When its really the radiator. fact not Fiction
A street type 440 at highway speeds doesnt need a fan at all period. A engine that over heats at idle and at stop lights only...yes the fan, but as you get the engine up to speed it should cool right off..If the opposite is true it only over heats during highway speeds, or tends to creep up..then its a circulation problem of some kind. either the radiator is plugged up, not large enough, the water pump is not working correctly (which if they arent weeping water or making a noise they are and the belt is turning it and not slipping etc).
A restriction of some kind, like mentioned a hose sucked together.
Re: clutch fan [Re: BLACKLINELAYER] #714514
06/02/10 11:10 PM
06/02/10 11:10 PM
IN
ahy Offline
ahy  Offline
IN
I've had great results with the MP repop stock style fan on a warm 496" B engine - with AC on and extended idling it holds 190 F on a 90+ day. I also agree based on experience that overheating on the highway isn't a fan problem - it usually means a plugged or too small radiator or (less likley) another "circulation" problem.
Re: clutch fan [Re: old yeller] #714515
06/02/10 11:10 PM
06/02/10 11:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What do you think a clutch fan does at highway speeds
Re: clutch fan [Re: MR_P_BODY] #714516
06/02/10 11:35 PM
06/02/10 11:35 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Roads ?!?
Where we're going , we don't need roads .
