2000 Dakota ABS #714443
06/02/10 06:31 PM
06/02/10 06:31 PM
New Hampshire
W
whitemtnelf Offline OP
W
New Hampshire
Hi,
I usually post about my '71 Charger but this time its about my 2000 4wd Dakota. The ABS and brake lights are on. I tried to pull the code and just get 'P done'. Any ideas on how to diagnose the problem?
Re: 2000 Dakota ABS [Re: whitemtnelf] #714444
06/02/10 06:48 PM
06/02/10 06:48 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
did you recently bleed your brakes? I have heard that air in the lines can cause this. Could also have a bad abs sensor.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: 2000 Dakota ABS [Re: whitemtnelf] #714445
06/02/10 07:00 PM
06/02/10 07:00 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Do the brake lights work right, and is the trailer wiring okay?
Re: 2000 Dakota ABS [Re: buildanother] #714446
06/02/10 07:59 PM
06/02/10 07:59 PM
New Hampshire
W
W
New Hampshire
The pads & shoes were replaced last summer, no other work has been done. The brake lights work. I haven't tried to use the trailer wiring for years.
Re: 2000 Dakota ABS [Re: whitemtnelf] #714447
06/02/10 09:08 PM
06/02/10 09:08 PM
Ohio
Todd Offline
Todd  Offline
Ohio
What scan tool were you using to pull the codes? If the ABS light is on there is a code there. There is a couple things that turn on both the red brake light and the abs light. One thing comes to mind is the brake fluid level sensor in the master cylinder. Until you find out what exactly the code is it's all just a guess at this point. DRB 3 scan tool should do the job.
Re: 2000 Dakota ABS [Re: whitemtnelf] #714448
06/03/10 08:19 AM
06/03/10 08:19 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
I would inspect/check your brakelines. Had 2(!) Dakota's a 93 and an 01 pop the lines the same day and in both instances both lights illuminated.
Common sense is a flower that does not grow in everybody's garden
Re: 2000 Dakota ABS [Re: Todd] #714449
06/03/10 07:08 PM
06/03/10 07:08 PM
New Hampshire
W
W
New Hampshire
I was just turning the ignition switch 3 times to get the codes. I'll probably have to go to Pep Boys or VIP to see if they can get the code.
I'll double check the fluid level.
