Re: What is This................................ [Re: STEFF] #713756
06/02/10 11:31 PM
06/02/10 11:31 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Steff...What are you up to??? Drag Pac car??
No Drag Pack Chally. Just a cool street/strip car. I'll post some pics later of what it is & my progress.
It never dawned on me that you weren't doing a drag pack Challenger..........which may speak about why they weren't flying off the shelves for other applications.
I am seeing more and more late Hemi's going into older cars.............finally.
I don't know whether to attribute it to fear of change or knowing what works and just not wanting to change.
But you are still pretty much the only kid on the block with a swap like this.
Re: What is This................................ [Re: tubtar] #713757
06/02/10 11:45 PM
06/02/10 11:45 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Looking good!!! What are you hoping to run with it and will it remain black??
Re: What is This................................ [Re: ZIPPY] #713758
06/03/10 03:55 AM
06/03/10 03:55 AM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
It's pretty sad ma gave up on this already. I know there are plenty of guys like me just waiting for more motors to trickle into the world for sale. Although I will stick with the efi, it's pretty hard for us Mopar guys to compete with lsx stuff when the parts just aren't offered.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: What is This................................ [Re: STEFF] #713759
06/03/10 08:05 AM
06/03/10 08:05 AM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
nice.........
Re: What is This................................ [Re: Bubba] #713760
06/03/10 08:11 AM
06/03/10 08:11 AM
tboomer Offline
tboomer  Offline
Steff...You sure do nice work!! All along I thought it was a Chally!!
Re: What is This................................ [Re: tboomer] #713761
06/03/10 10:13 AM
06/03/10 10:13 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
99% of people agree, therin lies the root of the problem......but as the supply of good OEM 340/360/5.9 engines dwindles.....that may no longer be true in the future.
It's the same mold with different machining for carb or efi, and if the world beats mp's door down for the carb intake, mp will make it. Nobody is asking for it currently though.
Another thing that didn't help was, the carb intake was mainly used as part of an 18 thousand dollar crate engine....but in it's heyday there were no pictures of it in the catalog or on the website. The carb crate engine made over 600HP on the dyno, yet the catalog says 540hp, which makes the manifold look pretty weak.
Trust me, it is not weak
Can't wait to get home and see Steve's pics....
darn firewall doesn't like 'em...
Rich H.
Esse Quam Videri
Re: What is This................................ [Re: ZIPPY] #713762
06/03/10 12:42 PM
06/03/10 12:42 PM
Almont, MI.
gdemon Offline
gdemon  Offline
Almont, MI.
Hey Steff
Looks good. Glad you found a intake. I was a little nervous.
Jerry
69 Barracuda 70 Cuda 70 Cuda 70 Cuda Conv. 70 T/A Challenger 70 Sport Fury GT 71 Demon 5.7 Hemi 72 Demon
Re: What is This................................ [Re: gdemon] #713763
06/03/10 11:10 PM
06/03/10 11:10 PM
wisconsin
swifter Offline
swifter  Offline
wisconsin
Isn't it possible to convert the efi to a carb mount??? Doesn't take but a good welder to fill the injector holes or what a minute put a fuel rail on it for n.o.s???? HUM sounds like an idea
2007 Ram 2500 Cummins 2008 Dodge Nitro 1970 340 Valiant Duster
Re: What is This................................ [Re: swifter] #713764
06/04/10 05:48 AM
06/04/10 05:48 AM
Smyrna, South Carolina
STEFF Offline OP
STEFF  Offline OP
I'm going to have some aluminum plugs made that have o-rings on them & insert them into the injector bores. With a little bit if blue Loctite they should be fine. I don't want to weld up the injector bores, should I decide to go to F.I. some day.
Hey Steff
Jerry
Thanx Jerry! I was getting a little nervous too & was glad to find a manifold.
Re: What is This................................ [Re: STEFF] #713765
06/04/10 12:52 PM
06/04/10 12:52 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
That sounds like a plan. Much easier to convert FI to carb than the other way around
Rich H.
Esse Quam Videri
Re: What is This................................ [Re: ZIPPY] #713766
06/04/10 04:01 PM
06/04/10 04:01 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Im jealous Steff
