Re: 440 source stealth heads: GOOD?? BAD??
[Re: 451Mopar]
#712609
06/01/10 08:11 AM
06/01/10 08:11 AM
Posts: 21,123 Niles , Ohio
therocks
Niles , Ohio
Mine are going on their third year.My 440 runs 12.5 Ross domes and street and strip.I did upgrade the locks retainers and springs which I would have done with Eddys.Just had to back cut the valves and cleaned them up a bit.Rocky
Chrysler Firepower
[Re: domingo]
#712613
06/01/10 04:14 PM
06/01/10 04:14 PM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
I have a friend who had his stealth heads crack too....he was running high compression. like 13:1 something like that.
thats why im asking.
Sounds like all he has to do is send 'em back to brandon for some good ones. Thats cool of Brandon to admitt to the problem, i'm sure he will make good on his promise. I bet ther are zillions of guys who have had no problems with them, and I still want a set for a future low deck project I'm working on.
[Re: moparmanjames]
#712614
06/01/10 04:25 PM
06/01/10 04:25 PM
Posts: 8,166 Left Coast
BobR
Left Coast
I guess I'm confused, I see a lot of bracket cars at the track running stock heads, I see stock eliminator cars running stock heads, and I'm guessing these Stealth heads flow better than stock from what I have read. Why would they not be race worthy if they flow better than stock both out of the box and ported? I would think it would depend on what you wanted to do and how fast you want to go. I see no reason why a set these CNC ported Stealth heads wouldn't be fine for a 3500lb bracket car running 10's all day long.
I guess that all depends on how fast you want to go. Mid 10's to me isn't what it used to be. Compare flow numbers of maxxed out Stealths to almost anything Indy makes but especially their top shelf stuff. Now compare this stuff to the better Ford and Chevy heads. I stand by what I said.
[Re: BobR]
#712615
06/01/10 04:56 PM
06/01/10 04:56 PM
Posts: 570 Ky
moparmafia
Ky
i think most people get caught up on flow numbers and dyno numbers. we might not have the most peak flow but the stock mopar heads have very good velocity and make good power. i have ran mopars my whole adult life and i have outrun many a ford and chevies that have higher flow numbers and an impressive dyno sheet. my very mild 1977 400 with stock 452 heads was out running my friends 93 mustang with edelbrock heads cam and intake. but man did his flow sheet look good. lol
[Re: BobR]
#712616
06/01/10 05:35 PM
06/01/10 05:35 PM
B1Fish540
Flint, Michigan
440Source does not claim that it is a race head. That is totally NOT its purpose. Its a stock replacement(almost identical)and is supposed to make a "stock looking" motor faster than it looks. And I think it succeeds for its intended purpose...plus, it is cheap. This may tempt alot of guys to use it for bracket or other limited type of racing. Just like the Eddy RPM. The flow numbers are pretty much the same for both. The RPM may look more like a race head but its not much better than a maxed out 906 iron head ..just like the Stealth. The BB Chev head, by its design, is an inherently a good flowing head just like a Hemi. So, you almost have to compare the BB mopar to a SB chevy...thats what it most closely resembles and the power can go from the most wimpy to fairly muscular...but not until serious changes are made in the design..ports, valve size and length etc etc,. Then you have a head that does not even look stock any more. The ports are much bigger and raised, the plugs are relocated and the head itself is taller and wider.
[Re: B1Fish540]
#712617
06/01/10 05:48 PM
06/01/10 05:48 PM
Posts: 744 Carson City, NV
440sourcedotcom
Carson City, NV
When comparing flow numbers from different companies, you are not comparing apples to apples. It is well known in the industry that certain companies greatly inflate their flow numbers, while others are much more accurate. The ONLY way to evaluate flow numbers is if all the heads you are comparing are flowed on the same calibrated flow bench, bolted to the same fixture (bore size), and flowed by the same person at the same time.
Bottom line is, several dozen of our CNC'd stealth heads have been dyno'd on 500+ CI engines. They make in the area of 675-725 horsepower everytime like clockwork.
We will be the first to tell you, if you are looking for 750+ HP, these are not the heads for you. If you are looking for 700/725 HP or less, (generally in the 9 second range for most cars) then they will be a good option, as they have been proven without a doubt to be capable of these power levels.
[Re: BobR]
#712619
06/01/10 06:03 PM
06/01/10 06:03 PM
B1Fish540
Flint, Michigan
I'd certainly(and have) buy a 440Source engine kit.I would not buy these heads-crack prone or not-for any kind of race car. For a street deal, fine, but the flow numbers coming out of these heads aren't race car worthy type figures.
Bob, I do understand where you are coming from(from other posts you have made)and I agree that the term "race head" should be confined to heads that have some of the modification I mentioned in my other post. In other words, they are considered exotic. Examples would be original B1, 440-1, Predator, B1-TS, Brewer, 426 Hemi..these heads are all capable of 1000+ HP. Even the Victor and mopar Stage VI are more "exotic" than "stock" so should be consider race heads. as well, imho.
[Re: 70RT Charger]
#712620
06/01/10 06:04 PM
06/01/10 06:04 PM
B1Fish540
Flint, Michigan
Im thinking about building a 512 stroker from 440 source and they recommend running the stealth heads or the Elderbrock Victor.I was told the same thing about the Stealth heads cracking,so whats the difference between the eddy Victor and the eddy rpm.I was told to go with a eddy victor?
about 100 HP!
[Re: 440sourcedotcom]
#712621
06/01/10 06:10 PM
06/01/10 06:10 PM
Posts: 30,632 Florida STAYcation
IcorkSOAK
Financed his waterbed
Florida STAYcation
CNCed ? .. how about the-best OOTB ??
And what would your grocery-list on that motor be?
[Re: IcorkSOAK]
#712622
06/01/10 06:36 PM
06/01/10 06:36 PM
440sourcedotcom
Carson City, NV
For the motors we are talking about, we are talking 500+ cubes, a cam at least .565+ lift, usually pump gas (10 to 10.5:1 compression - a few of the engines have been 12 or 13 to 1), roller rockers, 950-1050 carb, etc. Obviously, components must be matched correctly, and the engine must be tuned correctly, but there's no magic to it.
Out of the box, (non CNC version) most guys are making 540-560 HP with similar internal components as described above.
If you take the well known formula of CFM x .257 x number of cylinders, these horsepower numbers quoted are within the range of this formula, based on the CFM numbers we publish for our heads. This stuff is not rocket science and there's no mysteries to it, it's pretty simple and straightforward.
#712624
06/01/10 07:35 PM
06/01/10 07:35 PM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
Nice numbers, do you guys plan on offering a raised port/longer valve head anytime soon? Thanks
[Re: moparmanjames]
#712625
06/01/10 07:59 PM
06/01/10 07:59 PM
440sourcedotcom
Carson City, NV
Yes, our Stealth stage II heads are out of design and development and are currently in the pattern/tooling production stage. They may hit the market by the end of the year.
They will use an offset rocker to get rid of the "pushrod turn", but still have the exterior factory look and form factor (no cast in "intake spacers, raised valve covers, etc).
As far as flow numbers, we're getting peak numbers of about 325 cfm from them out of the box. On our same bench, out of the box victors flowed about 330, so they are holding their own with victors out of the box, however because of the raised port and longer valve design of the victors, the victors should have more potential with all out porting then our Stealth stage II. But we are confident the Stealth stage II should easily be an 800-850HP capable head.
#712626
06/01/10 08:03 PM
06/01/10 08:03 PM
B1Fish540
Flint, Michigan
Cool, will the price be comparable to the Pro Comp victors? They are about $1200, CNCed.
[Re: moparmafia]
#712627
06/01/10 08:10 PM
06/01/10 08:10 PM
Posts: 3,249 Between a rock & a hard place
cudadoug
I would agree 100% with this statement. I once ran a TRW flat top 440 (12+ years ago) going 10.30s @ 128 with 906 heads (263 peak CFM) at 3250-ish lbs. All of the "experts" said "no way, gotta be a stroker, where's the bottle"...I heard it all. Head flow, is just that: head flow, which is PART of the overall combo...
[Re: B1Fish540]
#712628
06/01/10 08:36 PM
06/01/10 08:36 PM
BobR
Left Coast
I agree.
