Re: avs 650 or 800 carb for a stock 383HP????????? [Re: Slipknot440] #712429
06/03/10 08:20 AM
06/03/10 08:20 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
if it helps any my hemi dynoed at 502 hp with a 750 dp on it and at 494 hp with an eddy 800 on it
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: JohnRR] #712430
06/03/10 02:58 PM
06/03/10 02:58 PM
Dalton, MA
Slipknot440 Offline
Slipknot440  Offline
Dalton, MA
506 with a holley. 501 with the eddy
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: Slipknot440] #712431
06/03/10 03:05 PM
06/03/10 03:05 PM
P
Paul_Fancsali Offline
P
I like a 800 on the 383 will get you at least.15 in qtr unless the sec are coming in too fast.I assume the 800 is avs version not the afb which if it is oh well!!!
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: Slipknot440] #712432
06/03/10 04:52 PM
06/03/10 04:52 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Was the Holley dialed in better? The air door alone takes some time with the AVS to get just right. Not counting jetting/rods.
I want my fair share
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: SomeCarGuy] #712433
06/03/10 08:59 PM
06/03/10 08:59 PM
Dalton, MA
Slipknot440 Offline
Slipknot440  Offline
Dalton, MA
the holley was my engine guys dyno carb. For anything under 500 cubes (as far as i can tell). But it was set up a lot better than my eddy, but that eddy only gave me problems
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: Slipknot440] #712434
06/03/10 09:41 PM
06/03/10 09:41 PM
SomeCarGuy Offline
SomeCarGuy  Offline
Really? What was wrong with the 800 AVS? I haven;t seen anybody saying that they had trouble with the AVS carbs.
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: SomeCarGuy] #712435
06/03/10 10:20 PM
06/03/10 10:20 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
They are very forgiving carbs. Air door
vs. Vac sec/mech sec, Air doors are nearly foolproof and less chance of vacuum leaks!!!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: HYPER8oSoNic] #712436
06/03/10 10:39 PM
06/03/10 10:39 PM
own private Idaho
N
ngpSatellite Offline OP
N
own private Idaho
bought the 650 AVS eddy and it has much better performance then the 750 eddy AFB it replaced!! hands down Very nice low end pick up!!! seems perfect for the 383HP bone stock engine. ...thanks for all the advice!
Re: avs 650 or 800 carb for a stock 383HP????????? [Re: Slipknot440] #712437
06/03/10 10:56 PM
06/03/10 10:56 PM
Desert Tracker
Desert Tracker
Very close, the DP forces the HEMI to rpm quicker!!
