is this a good casting #3614230-5 400 block #712303
05/31/10 02:10 PM
05/31/10 02:10 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
finally picked up the 400 block. this will be the foundation for my 512 project if it checks out ok. cast in 12-6-71 with 3614230-5. what does the -5 stand for? the bores measure standard with very little to no wear.
Re: is this a good casting #3614230-5 400 block [Re: mopar dave] #712304
05/31/10 02:17 PM
05/31/10 02:17 PM
Suburb of Chicago, IL
BCFKody Offline
BCFKody  Offline
Bad news, this one is not the heavy main web cold weather casting. All the "230" blocks cast after 10/10/71 have the standard main webs.
Re: is this a good casting #3614230-5 400 block [Re: mopar dave] #712305
05/31/10 02:19 PM
05/31/10 02:19 PM
NC
440Jim Offline
440Jim  Offline
NC
That looks to be cast too late to be a heavy main web block, see attached. I believe the -5 means the core had 5 repairs (common).
But if the cylinder wall thickness checks good (sonic check), it should be a good block to start with.
Re: is this a good casting #3614230-5 400 block [Re: BCFKody] #712306
05/31/10 02:19 PM
05/31/10 02:19 PM
Mt Morris Michigan
Mt Morris Michigan
i did'nt think it was. the heavy web castings were cast between apr and oct of 71, but is this still a good candidate for a 700+hp 512?
Re: is this a good casting #3614230-5 400 block [Re: BCFKody] #712307
05/31/10 02:20 PM
05/31/10 02:20 PM
Renton Washington
Triple Threat Offline
Renton Washington
Any block is subject to core shift which is the enemy, only way to know for sure is to have it sonic checked.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: is this a good casting #3614230-5 400 block [Re: mopar dave] #712308
05/31/10 02:22 PM
05/31/10 02:22 PM
Mt Morris Michigan
Mt Morris Michigan
the webbing in this block does look thick like the pic you posted and the casting numbers are large. can you explain the casting core repairs to get a -5?
Re: is this a good casting #3614230-5 400 block [Re: Triple Threat] #712309
05/31/10 02:23 PM
05/31/10 02:23 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
So aside from the obvious sonic check/core shift numbers. It's still a good candidate stock block to use.
Not THEE very best (which would be a thick web 230 casting), but probably the 2nd best in my opinion...
Re: is this a good casting #3614230-5 400 block [Re: dizuster] #712310
05/31/10 02:23 PM
05/31/10 02:23 PM
Mt Morris Michigan
Mt Morris Michigan
thats good to hear.
Re: is this a good casting #3614230-5 400 block [Re: mopar dave] #712311
05/31/10 02:26 PM
05/31/10 02:26 PM
NC
440Jim Offline
440Jim  Offline
NC
Look at the main webs from both the front of the block and the rear. Check the 440source web site for more pics to see the difference. Sometimes a web looks thick from one side but it isn't on the other.
Re: is this a good casting #3614230-5 400 block [Re: BCFKody] #712312
05/31/10 02:37 PM
05/31/10 02:37 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Is that really a problem? My 400 came from a 73 truck and is going on 11 years w/one redo....
Re: is this a good casting #3614230-5 400 block [Re: Thumperdart] #712313
05/31/10 02:47 PM
05/31/10 02:47 PM
Mt Morris Michigan
Mt Morris Michigan
heres a few pics.
Re: is this a good casting #3614230-5 400 block [Re: mopar dave] #712314
05/31/10 02:51 PM
05/31/10 02:51 PM
Mt Morris Michigan
Mt Morris Michigan
another
Re: is this a good casting #3614230-5 400 block [Re: mopar dave] #712315
05/31/10 02:54 PM
05/31/10 02:54 PM
Mt Morris Michigan
Mt Morris Michigan
one more
Re: is this a good casting #3614230-5 400 block [Re: mopar dave] #712316
05/31/10 02:56 PM
05/31/10 02:56 PM
NC
440Jim Offline
440Jim  Offline
NC
That doesn't look like the thick web block.
Re: is this a good casting #3614230-5 400 block [Re: 440Jim] #712317
05/31/10 03:03 PM
05/31/10 03:03 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
It looks like a standard one to me, and it could still be a good candidate.
Rich H.
Esse Quam Videri
Re: is this a good casting #3614230-5 400 block [Re: 440Jim] #712318
05/31/10 03:10 PM
05/31/10 03:10 PM
Mt Morris Michigan
Mt Morris Michigan
ok, i did look at the webbing on both sides and the mains are thicker than the webbing on both sides if that meens anything. about .155" each side.
Re: is this a good casting #3614230-5 400 block [Re: mopar dave] #712319
05/31/10 03:33 PM
05/31/10 03:33 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
as far as the -5, I believe that is the core box number that it was poured in.
Re: is this a good casting #3614230-5 400 block [Re: dartman366] #712320
05/31/10 04:16 PM
05/31/10 04:16 PM
Mt Morris Michigan
Mt Morris Michigan
i'd like to find an article about the core # to read so i can understand this better.
Re: is this a good casting #3614230-5 400 block [Re: mopar dave] #712321
05/31/10 04:53 PM
05/31/10 04:53 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
The main webbing is important but equally important are the thickness of the thrust side ribbing in terms of how well the block was cast. This one was a -2
This 230 I used for my 517 was about average in terms of the 230 main webbing but it was an exceptionally cleanly cast block with very strong ribbing and a very straight cam bore. of the I don't know how many B/RB's I've built over the years this one jsut fell together and turned super smooth. Expert Machining of the block and crank go a long way in terms of the motor not fighting itself....the webbing is a key factor but even the worst 400's I've seen are still thicker inthe main webs than nearly all 440's.
I've seen several thick web blocks that had bore thrust sides so thin they needed sleeves to even go +.030. And some may have horrific cam core shift. Webbing is important but to me it's not the single most important factor in block selection.
WIZE
In Car:
Re: is this a good casting #3614230-5 400 block [Re: Streetwize] #712322
05/31/10 06:02 PM
05/31/10 06:02 PM
Mt Morris Michigan
Mt Morris Michigan
thanks for this info guys. after reading the 440source article on engine blocks i do not have the cold weather block for sure. no mistaking it from a standard 400 block.
