Wheelie Bar/Chassis Questions
#711213
05/30/10 07:15 AM
05/30/10 07:15 AM
Posts: 3,862 N.E. Ohio
6bblFLASH
N.E. Ohio
I`m having a small issue with what I assume is the wheelie bars,more than the actual chassis set-up. Problem started with still being wheels-up for the 1-2 shift. So lowered the wheeliebars and stiffen the springs on them. That works SOME of the time. Now if the front gets higher than say 30in`s the car goes hard left AFTER its reach max height. If I keep the w/bars low and stiff I can avert the height/left issue but on poor tracks like yesterday I blow the tires off since it nevers get up on the rear. So I took spring out of the w-bars . Hook improved but after the weather and track changed ,more power more hook. Off in the grass we went. I have video of yesterday{no I can`t figureout how to post} And what it does,leaves straight and square.After it reaches max height,goes left quickly. Looks alot like a pulling tractor when he jabs one brake to correct on 2-wheels.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
Post deleted by Defbob
[Re: 6bblFLASH]
#711214
05/30/10 10:02 AM
05/30/10 10:02 AM
Re: Wheelie Bar/Chassis Questions
#711215
05/30/10 10:16 AM
05/30/10 10:16 AM
6bblFLASH
N.E. Ohio
Ladderbars,coilovers,single adj. Aldon? shocks. 90/10 fronts,otherwise stock susp. Not shooting for the moon,but want some airtime. When it pulled big wheelies it went straight but 2nd gear was a constant issue.Smashed the pan several times trying to shift before it came down. Lowered and stiffened the w-bars and that worked till it started spinning.
Re: Wheelie Bar/Chassis Questions *DELETED*
[Re: 6bblFLASH]
#711216
05/30/10 10:46 AM
05/30/10 10:46 AM
Post deleted by SUPERSTOCKRACER
[Re: 6bblFLASH]
#711217
05/30/10 10:58 AM
05/30/10 10:58 AM
#711218
05/30/10 11:00 AM
05/30/10 11:00 AM
6bblFLASH
N.E. Ohio
Well I don`t think its just that simple. Are you saying of the 1,000`s of cars running w-bars,we ALL have our heads up our a-s? My car has over 50% weight on the rear tires and makes good torq.Your car is a heavy automatic. Apples to Oranges.
#711219
05/30/10 11:19 AM
05/30/10 11:19 AM
6bblFLASH
N.E. Ohio
Bar is in lowest hole,already limited some travel. Will try more. Next set of tires will be smaller and take out some hook.
[Re: 6bblFLASH]
#711222
05/30/10 11:59 AM
05/30/10 11:59 AM
i wasnt going to reply.should have gone with my gut.
[Re: 6bblFLASH]
#711224
05/30/10 06:03 PM
05/30/10 06:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Good advise,I`ll consider that
Up your rear tire pressure a 1/8 pound then check it again... dont try to dead hook... if you get UP on the tire some it'll 60' better and the front wont climb as high..... DONT try steering the car with the WB you can mildly assist it with them
[Re: acme383]
#711225
05/30/10 10:41 PM
05/30/10 10:41 PM
superstockracer, here's the video you've been looking for. now you can change your signature!
http://www.youtube.com/watch?v=2_OXcw0eqVI
who the heck are you?
[Re: B G Racing]
#711229
05/31/10 10:16 AM
05/31/10 10:16 AM
