Re: Wierd fuel pressure problem [Re: therocks] #709275
05/30/10 10:40 AM
05/30/10 10:40 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
I'm using the smaller summit electric that does not require the regulator and have a steady 8 PSI. I don't run a return line. I'm only running a Holley 750 though.
Re: Wierd fuel pressure problem [Re: ireland383] #709276
05/30/10 10:58 AM
05/30/10 10:58 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Did you check the vent yet? Leave the gas cap off and check the pressure again. Are you measuring pressure before or after the filter?
Kevin
Re: Wierd fuel pressure problem [Re: Twostick] #709277
05/30/10 12:13 PM
05/30/10 12:13 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
what he said
Re: Wierd fuel pressure problem [Re: VanishPt] #709278
05/30/10 12:20 PM
05/30/10 12:20 PM
Niles , Ohio
therocks Offline OP
therocks  Offline OP
Niles , Ohio
Had the cap off and checked pressure before and after the filter.Its the same.I was playing with my old Holley pumps and it looks like the arm on the newer one is short like 1/16 inch than the old ones.I know the one I bought in 71 is shot for sure.The new arm dosent look worn.I wonder if it could be slightly bent?Ill have to pull the carter and see if the arm is as long.Rocky
Chrysler Firepower
Re: Wierd fuel pressure problem [Re: therocks] #709279
05/30/10 12:27 PM
05/30/10 12:27 PM
V
VanishPt Offline
VanishPt  Offline
V
you had the cap off in the same situation as you experienced the low pressure?
Or did you take the cap off a while after the situation?
Re: Wierd fuel pressure problem [Re: VanishPt] #709280
05/30/10 12:29 PM
05/30/10 12:29 PM
Niles , Ohio
therocks Offline OP
therocks  Offline OP
Niles , Ohio
Checked it with it on and off.Pressure was the same.Rocky
Chrysler Firepower
Re: Wierd fuel pressure problem [Re: therocks] #709281
05/30/10 12:32 PM
05/30/10 12:32 PM
V
VanishPt Offline
VanishPt  Offline
V
did you have the cap off at 50 mph?
Re: Wierd fuel pressure problem [Re: VanishPt] #709282
05/30/10 12:36 PM
05/30/10 12:36 PM
Niles , Ohio
therocks Offline OP
therocks  Offline OP
Niles , Ohio
No the cap was on doing 50.But If it was bad it would make a difference even idling.I believe the 65 used a non vented cap.Its been on since 65.Rocky
Chrysler Firepower
Re: Wierd fuel pressure problem [Re: therocks] #709283
05/30/10 07:12 PM
05/30/10 07:12 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Could be the sock in the tank. Could also be a collapsed hose. I've even seen rags in a fuel tank blocking the pick up. You usually find something like that AFTER you've replaced the entire fuel system tho . You could put a tee in the suction hose at the pump and hook up a vacuum gauge. That would tell you if you have a restricted suction line.
Re: Wierd fuel pressure problem [Re: therocks] #709284
05/30/10 10:50 PM
05/30/10 10:50 PM
Kenosha, WI wi/il border
BobN Offline
BobN  Offline
I went through this last summer on my 440.
low fuel pressure, stalling, then starting right back up?
running like crap.
opening gas cap seemed to help.
replaced sending unit and fuel pump .
Turned out my fuel pump push rod was 1/2" short on one end/
replaced that rod and all seems find now.
