Help, Quarter Stick Neutral Safety Switch #708169
05/26/10 08:58 AM
05/26/10 08:58 AM
NC
chris3 Offline OP
chris3  Offline OP
NC
Anyone who has installed the neutral safety switch for the Hurst Quarter Stick. The Jegs and Hurst shows the switch with two female terminal ends included. Where are the male ends on the switch. The switch is on the shifter, in the car, and has never been wired up. Anyone familiar with this switch?
Re: Help, Quarter Stick Neutral Safety Switch [Re: chris3] #708170
05/26/10 09:05 AM
05/26/10 09:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
That switch goes between your starter button...
out of button to switch then out of switch to the
starter solenoid ... its all in line
Re: Help, Quarter Stick Neutral Safety Switch [Re: MR_P_BODY] #708171
05/26/10 09:19 AM
05/26/10 09:19 AM
NC
chris3 Offline OP
chris3  Offline OP
NC
Thanks. I have the switch on the shifter; however, I can not find where the two male connectors are on the switch for the connection of the two female wire connectors. Don't know if it is inside the switch. We do not have the installation instructions.
Re: Help, Quarter Stick Neutral Safety Switch [Re: chris3] #708172
05/26/10 09:25 AM
05/26/10 09:25 AM
New Jersey
barryc Offline
barryc  Offline
New Jersey
The switch is mounted under the shifter. It is difficult to see the terminals. They are on the bottom of the switch. had to use small needle nose to get the wires on.
Re: Help, Quarter Stick Neutral Safety Switch [Re: barryc] #708173
05/26/10 09:57 AM
05/26/10 09:57 AM
NC
chris3 Offline OP
chris3  Offline OP
NC
Thanks Guys. Barry that is what I was thinking. The shifter was mounted in the car when we got it. The switch is there it has not ever been hooked up. Thought I might have to take the shifter out to hook it up. Thanks again.
Re: Help, Quarter Stick Neutral Safety Switch [Re: chris3] #708174
05/26/10 10:04 AM
05/26/10 10:04 AM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
why not use the factory NSS?????
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: Help, Quarter Stick Neutral Safety Switch [Re: StripeHOG] #708175
05/27/10 11:15 AM
05/27/10 11:15 AM
NC
chris3 Offline OP
chris3  Offline OP
NC
Can you use a factory neutral safety switch on a 727 with a reverse, manual, valve body?
Re: Help, Quarter Stick Neutral Safety Switch [Re: chris3] #708176
05/27/10 11:18 AM
05/27/10 11:18 AM
tboomer Offline
tboomer  Offline
Yes...On a 727 the two outside prongs are for the back up lights...The center one is for the nss...
Re: Help, Quarter Stick Neutral Safety Switch [Re: chris3] #708177
05/27/10 11:20 AM
05/27/10 11:20 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
Yes you can,i,ve used mine for years. i use the one on the shifter wired as a safety to keep my electric shifter from activating in neutral or park.
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
