Re: making patch panels
[Re: KingMopar]
#7083
11/17/03 02:02 AM
11/17/03 02:02 AM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
I have hesitated to say this, but what the heck! What I have done in the past with a complicated piece like this is to take my steel and mark the lines I need to bend along on the backside. I then take my die grinder with a thin wheel, and I "scribe" it. As it thins the metal out along where it needs to be bent, it makes shaping the curves much easier. Then I set my welder down low and weld along the inside where the scribe is to add strength. It's probably not the best way to do it, but it's strong, makes life alot simpler for a novice, and certainly gets the job done.
2 Demons...no, not my kids!
[Re: 4speeds4me]
#7084
11/17/03 12:21 PM
11/17/03 12:21 PM
I like to cut out the original piece to good metal, take the piece you cut out and flatten it out to use as a pattern for the new patch, cut the new patch, and bend to the contours of the existing metal.
It takes practice, practice, practice!
[Re: Molloy]
#7086
11/17/03 03:21 PM
11/17/03 03:21 PM
Molloy, try taking a water-soaked rag and cool down the area after a couple of welds.
I had the same problem until I started doing this.
[Re: Jerry]
#7089
11/17/03 09:45 PM
11/17/03 09:45 PM
