First race of the Year Results WTTTF
#705937
05/23/10 07:55 PM
05/23/10 07:55 PM
Posts: 1,138 San Angelo, Texas
W8n2DustU
San Angelo, Texas
We had our season opener yesterday here at Desert Thunder Raceway. We had to replace the head gaskets in the car this week after doing a leakdown. Any how our first pass in qualifying resulted in a 5.30@ 137.87 and a 1.31 sixty foot. Second qual. we added 5# of fuel pressure across the board and went 5.25@138.79 with another 1.31 sixty foot. We were #1 qualifier and went on to win the event. Our first two elimination rounds did not go great as we were trying different stuff but were able to win each round. In the finals we went back to the 5.25 tuneup and ran a 5.28@138.19. Car weighed in at 3307#.The converter will be changed out this week. It was way to tight for the motor. After the shift we only gained another 100 rpm's. We did make 34# of boost at 8800 rpm's. We will raise the shift point up to 9200 our next outing. With the data we have and a new converter a 4.90 is well in reach.
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
Re: First race of the Year Results WTTTF
[Re: W8n2DustU]
#705938
05/23/10 08:00 PM
05/23/10 08:00 PM
Posts: 437 south central pa
bdaz smblk
south central pa
Great job to you and your crew.Keep up the good work and glad to see the car is running great with very little tunning.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
[Re: W8n2DustU]
#705941
05/23/10 08:03 PM
05/23/10 08:03 PM
Posts: 2,987 A shed in England
Tig
A shed in England
Awesome I want a procharger
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#705942
05/23/10 08:24 PM
05/23/10 08:24 PM
Posts: 2,792 IN
Dartman928
IN
I second that
Great job
[Re: blown572dart]
#705944
05/23/10 08:42 PM
05/23/10 08:42 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
[Re: 340RICK]
#705946
05/23/10 09:28 PM
05/23/10 09:28 PM
Stupendous.........
[Re: Dartman928]
#705951
05/23/10 11:33 PM
05/23/10 11:33 PM
Posts: 1,329 St. Louis, MO
mopardamo
St. Louis, MO
I second that
Great job
I want in on that bandwagon.
Damon
[Re: SB412DUSTER]
#705953
05/24/10 07:51 AM
05/24/10 07:51 AM
W8n2DustU
San Angelo, Texas
Thanks guys. It has been a long layoff having to make all the changes to the car and combo. But it was well worth it. The W8 heads are probably not the best choice for a blower but we wanted to see how they worked. We will continue to test until we have alot more data.
[Re: 66coronet]
#705955
05/24/10 10:11 AM
05/24/10 10:11 AM
Posts: 19,544 Las Vegas
Al_Alguire
Las Vegas
Congrats onthe win, alwasy good to have some hardware and a check. Looks like all the work has paid off, good luck this season.
