power windows #704398
05/21/10 04:15 PM
05/21/10 04:15 PM
desomod Offline OP
desomod  Offline OP
Any recommendations for power windows (aftermarket OK) for '70 Cuda fronts?
Re: power windows [Re: desomod] #704399
05/21/10 04:35 PM
05/21/10 04:35 PM
MI.
mech440 Offline
mech440  Offline
MI.
http://www.a1electric.com/electriclifewind.htm
I got mine for my belvedere from a1electric(link above) Installed with ease and seem to work fine so far. Hope this helps.
Mech
If it doesn't have a motor.....it's not a REAL sport
Re: power windows [Re: mech440] #704400
05/21/10 05:11 PM
05/21/10 05:11 PM
desomod Offline OP
desomod  Offline OP
Thanks for the link. Was it a pretty much bolt in deal or was there alot of modifications to make it work? Did you use any of your door guts or are they all replaced with the kit?
Re: power windows [Re: desomod] #704401
05/21/10 05:12 PM
05/21/10 05:12 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
also Spal makes them, www.spalusa.com I sell both
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: power windows [Re: desomod] #704402
05/21/10 05:19 PM
05/21/10 05:19 PM
Unfortunately back in New York
N
Nukechargerboy Offline
N
Mine pretty much bolted right in, but you have to drill a hole in the doors and the door jamb for the wiring. I wish I went with the contacts they sell. GM switches. Not a bad setup, a little pricey though. My backs are still manual though, didn't see the point because nobody sits back there.
Re: power windows [Re: Nukechargerboy] #704403
05/21/10 05:36 PM
05/21/10 05:36 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
I have a1electric for my RR but it's about 4 steps away from putting them in, I heard go things about both systems
Re: power windows [Re: deansrr] #704404
05/21/10 06:55 PM
05/21/10 06:55 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
I have http://www.electric-life.com/ in my '98 Ram. Its their scissor type which is a basic stock replacement. Bolted in with no mods other than the switches (which you have to buy in a separate kit unfortunately ) They claim the scissor type is the smoothest and mine are smooth as silk I want them for my Challenger. I'm very happy with the results in my Ram
Re: power windows [Re: Scott Carl] #704405
05/21/10 06:58 PM
05/21/10 06:58 PM
BDW Offline
BDW  Offline
Glad you guys had success with the A1 kit. I tried it on my Challenger and it was very disappointing. Went back to manual.
Read through this, once people are pressed they admit the A1 stuff isn't the greatest.
http://www.cuda-challenger.com/cc/index.php?topic=45919.0
When I tried them, they went down so fast it broke the rubber bump stop. and it struggled to raise. It was not an adjustment issue, as I did all the testing without the door panels on and the door open. Luckily I didn't cut my panels before trying them.
Re: power windows [Re: BDW] #704406
05/21/10 07:07 PM
05/21/10 07:07 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
That is disappointing to hear. I just looked at the A1 link and they say its made by electric life I'm so happy with the ones in my truck I figure they'd work as good in my car....Perhaps a geometry design flaw for the e-bodies
Re: power windows [Re: Scott Carl] #704407
05/22/10 12:06 AM
05/22/10 12:06 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I used a generic spal kit in my 87 daytona and a knock off of a spal kit in my brother's 83 rampage. Both work perfect. And I must say, the windows on my 87 daytona were harder to hand crank than those in any old mopar I've ever owned and the spal kit does the job just fine. Only downside is the cap you have to put over where your manual cranks would normally go.
