Re: TIRE SIZE FOR CUDA??
[Re: kingkt]
#704067
05/21/10 10:21 AM
05/21/10 10:21 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Suggestion = Use the search function. This topic has been covered at length for years.
Comment = You are ultimately limited by the narrow rim size and backspacing you have.
Request = Take off the CAP LOCK!
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: kingkt]
#704070
05/21/10 12:23 PM
05/21/10 12:23 PM
Posts: 4,720 Moved to N.E. Tennessee
GomangoCuda
PLEASE TURN OFF THE CAPSLOCK.
Please turn off the capslock.
Now which one do you think is easier to read?
275-60R-15 will usually fit on the rear with 8" wheels with 4.5" backspace. They will be close to the wheelwell lip if the car is low and might need a little cut and/or bend where they are close. If it is higher in the rear like with SS springs then no problem.
[Re: GomangoCuda]
#704071
05/21/10 12:24 PM
05/21/10 12:24 PM
Posts: 2,403 WASHINGTON, PA
11secaarcuda
WASHINGTON, PA
275 60 15 rear, 235 60 15 front BFG Radial TA. Personally, I wish the fronts were just a little taller.
67 Dart GT 340 4 speed 70 AAR Cuda 408 6 barrel 96 Indy Ram original owner 2011 Hemi Durango
[Re: GomangoCuda]
#704076
05/21/10 03:19 PM
05/21/10 03:19 PM
Posts: 2,826 NY usa
540challenger
NY usa
you young guys might be able to see the smaller letter better. but us old farts see the larger letters better. anyways thank you for the info.i appreciate it to all.
Please define "young guys" and "Old Farts". What hair I have left is white and I have grandkids in college. Am I an old fart?
Being an old fart is not defined by the color of your hair but rather how many places on your body it is now growing.
