TIRE SIZE FOR CUDA?? #704066
05/21/10 09:35 AM
05/21/10 09:35 AM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
I TRYING TO FIND OUT THE LARGEST SIZE TIRE TO FIT INSIDE THE WHEEL WELL OF A 71 CUDA? I HAVE 15X7 RALLY'S. I PLAN ON PUTTING THE BF GOODRICH TA TIRES. I WANT TO GET THE WIDEST TIRE I CAN. ANY SUGGESTIONS? THANK YOU
Re: TIRE SIZE FOR CUDA?? [Re: kingkt] #704067
05/21/10 10:21 AM
05/21/10 10:21 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Suggestion = Use the search function. This topic has been covered at length for years.
Comment = You are ultimately limited by the narrow rim size and backspacing you have.
Request = Take off the CAP LOCK!
Re: TIRE SIZE FOR CUDA?? [Re: kingkt] #704068
05/21/10 10:25 AM
05/21/10 10:25 AM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Hello, You are sort of limited on width with the 7" wide wheels. I just put P275/60R15 (rear) and P235/60R15 (front) on a friend's '71 'Cuda convert. Personally, I think it looks too big on the rear, but he loves it! The P275/60's fill up the wheel-well. Jeff
Re: TIRE SIZE FOR CUDA?? [Re: 1969RR] #704069
05/21/10 11:44 AM
05/21/10 11:44 AM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
THANK YOU FOR THE INFO. HOPE YOU IGHT BE ABLE TO POST A PICTURE. I REALLY WANT TO BUY TIRES ONE TIME..THANK YOU
Re: TIRE SIZE FOR CUDA?? [Re: kingkt] #704070
05/21/10 12:23 PM
05/21/10 12:23 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
PLEASE TURN OFF THE CAPSLOCK.
Please turn off the capslock.
Now which one do you think is easier to read?
275-60R-15 will usually fit on the rear with 8" wheels with 4.5" backspace. They will be close to the wheelwell lip if the car is low and might need a little cut and/or bend where they are close. If it is higher in the rear like with SS springs then no problem.
Re: TIRE SIZE FOR CUDA?? [Re: GomangoCuda] #704071
05/21/10 12:24 PM
05/21/10 12:24 PM
WASHINGTON, PA
11secaarcuda Offline
WASHINGTON, PA
275 60 15 rear, 235 60 15 front
BFG Radial TA. Personally, I wish the fronts were just a little taller.
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: TIRE SIZE FOR CUDA?? [Re: GomangoCuda] #704072
05/21/10 01:41 PM
05/21/10 01:41 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
you young guys might be able to see the smaller letter better. but us old farts see the larger letters better. anyways thank you for the info.i appreciate it to all.
Re: TIRE SIZE FOR CUDA?? [Re: kingkt] #704073
05/21/10 02:00 PM
05/21/10 02:00 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Grandpa, you don't have to be old to have vision problems.
On your key board on the lower left is the key 'Ctrl' Push that and at the same time the '+' by your number key.
If too big push the 'Ctrl' key again and at the same time push the '-' by your number key.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: TIRE SIZE FOR CUDA?? [Re: jbc426] #704074
05/21/10 02:23 PM
05/21/10 02:23 PM
CHRGR69 Offline
CHRGR69  Offline
Observation = Lighten up!
Grandma always said I had "hands of gold"!
Re: TIRE SIZE FOR CUDA?? [Re: kingkt] #704075
05/21/10 02:32 PM
05/21/10 02:32 PM
GomangoCuda Offline
GomangoCuda  Offline
Please define "young guys" and "Old Farts". What hair I have left is white and I have grandkids in college. Am I an old fart?
Re: TIRE SIZE FOR CUDA?? [Re: GomangoCuda] #704076
05/21/10 03:19 PM
05/21/10 03:19 PM
NY usa
540challenger Offline
NY usa
Being an old fart is not defined by the color of your hair but rather how many places on your body it is now growing.
Re: TIRE SIZE FOR CUDA?? [Re: 540challenger] #704077
05/21/10 04:27 PM
05/21/10 04:27 PM
mohnton pa
rva Offline
super gas
rva  Offline
super gas
mohnton pa
i went with 225/70 on front and 255/60 on rear looked great, not to big nor small,the 225/70s are taller and match well with the 255/60s this was on a 70 challenge rt/se 446
Re: TIRE SIZE FOR CUDA?? [Re: rva] #704078
05/21/10 08:28 PM
05/21/10 08:28 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
P275/60 rear, P235/60 front on a 1971 'Cuda.
Re: TIRE SIZE FOR CUDA?? [Re: CHRGR69] #704079
05/21/10 09:11 PM
05/21/10 09:11 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Definition = hypocrisy
Don't be the exception.
Re: TIRE SIZE FOR CUDA?? [Re: Supercuda] #704080
05/21/10 09:37 PM
05/21/10 09:37 PM
Queensland,Australia
T-bar Offline
T-bar  Offline
Hello all i've got 29x12.5x15 Mickey Thompson Sportsmans on the back with leaf springs relocated inboard. They are a touch big, gaurds are rolled but they just rub on the inner wheel well. 225/70r15 on front love the look of big tyres on the back. 1970 Cuda
Re: TIRE SIZE FOR CUDA?? [Re: HealthServices] #704081
05/21/10 09:54 PM
05/21/10 09:54 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
WHOA....That is very cool....I had no idea you could do that !
CHECK OUT MY NEW WEB SITE !
Re: TIRE SIZE FOR CUDA?? [Re: kingkt] #704082
05/21/10 09:58 PM
05/21/10 09:58 PM
anlauto Offline
anlauto  Offline
I forget the size of these MONSTERS but they were too big on a 7" rim and rubbed like crazy...
Re: TIRE SIZE FOR CUDA?? [Re: kingkt] #704083
05/21/10 10:25 PM
05/21/10 10:25 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I've had 275x60 on 7" Rallyes, 245x60 up front. It's not recommended to run a 275 on a 7" wheel. I won't do it again.
A 255 on a 7" is better. If you just got to have a 275, use the aftermaket 8" wheels.
Re: TIRE SIZE FOR CUDA?? [Re: B5 Bee] #704084
05/21/10 10:53 PM
05/21/10 10:53 PM
southern California
1970sixpak Offline
1970sixpak  Offline
southern California
275-60-15 is the biggest you can fit without moving the leafs in. Your 15X7's will have to be the stock offset(4.25) as well for the 275's to fit. They will rub a bit as well. if you don't want to deal with any of that go with the 255's.
Re: TIRE SIZE FOR CUDA?? [Re: kingkt] #704085
09/01/11 06:04 PM
09/01/11 06:04 PM
NEW YORK
SIXPAK440 Offline
SIXPAK440  Offline
NEW YORK
I AGREE I ALWAYS GET CHASTISED FOR CAP LOCK BUT I CAN SEE IT MUCH BETTER NOT YELLIN JUS JELLIN
