f/m/j sub frame #703203
05/20/10 12:40 PM
05/20/10 12:40 PM
shepherdsville, ky 40165
stevieh Offline OP
stevieh  Offline OP
hello everyone, new to this, i have a 1948 dodge sedan and want to put a new sub frame under it, looking for complete unit for volare etc., 100 miles or so from louisville, ky. any advice would be appreciated, 1978 440 w/727 combo going in also,
Re: f/m/j sub frame [Re: stevieh] #703204
05/20/10 07:11 PM
05/20/10 07:11 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Check on parts availability!
I have not done so, but I have heard here and on other boards that the parts are getting harder to find for the late 70s- early 80s stuff.
Even if you can find them now, my is that a Dakota clip will have better parts availability in the next 10 years. It also is a newer design with more aftermarket (spindles, big brakes, etc.) support than the FMJ.
http://louisville.craigslist.org/pts/1730036998.html
http://louisville.craigslist.org/cto/1730686999.html
Re: f/m/j sub frame [Re: RodStRace] #703205
05/20/10 07:20 PM
05/20/10 07:20 PM
stevieh Offline OP
stevieh  Offline OP
hello, thanks for responding, does the sub unbolt like the other? i think it would be better if so, like you said for the availablity of parts alone, what would you want for the sub? again thanks for getting back, steve
Re: f/m/j sub frame [Re: stevieh] #703206
05/20/10 07:28 PM
05/20/10 07:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
There is no problem with parts availability for the F/M/J suspension.
They made it till 89 and to be honest I'd use as late a version as you can get. They were beefed up over the years and the last few years are the best.
Don't be the exception.
Re: f/m/j sub frame [Re: Supercuda] #703207
05/20/10 07:52 PM
05/20/10 07:52 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
They now make every part needed to rebuild the F.M J front ends, now even the transverse tor. bars are being made but are costly.
Re: f/m/j sub frame [Re: quick77rt ] #703208
05/20/10 08:35 PM
05/20/10 08:35 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Thanks guys, sorry for the bad info.
I sure hope the OP doesn't think the subframe will bolt in to the other frame....
Re: f/m/j sub frame [Re: RodStRace] #703209
05/20/10 09:00 PM
05/20/10 09:00 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
I didnt even read that part, but in the past couple years alot of companies have stepped up and made the parts, the most recent, the t-bars and cost the most $$$.
Whats up with the crown vic front ends being swapped as well???
Re: f/m/j sub frame [Re: stevieh] #703210
05/20/10 09:19 PM
05/20/10 09:19 PM
stevieh Offline OP
stevieh  Offline OP
hello, i know i will have to weld in and fit, i didn't want to destroy my frame, i thought about camaro but i would rather keep it mopar, i like the idea of dakota sub, i know i sound like a idiot, but will a 5 speed from a v6 bolt to a 440? and does anyone know the width of the sub and rear end? sorry i am new to this, my son is the welder and fabicator, thanks in advance, steve
Re: f/m/j sub frame [Re: stevieh] #703211
05/21/10 09:11 AM
05/21/10 09:11 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i have a 47 desoto and a 88 dakota frame that i`m grafting together. i remember measuring a few years ago and the dakota frame was 1" wider per side than the desoto frame. the v6 5speed will not bolt to the 440, it would bolt to a small block though. i THINK the 5 speeds were a one piece trans, as in the bell doesn`t seperate from the trans. like the 833`s.
Re: f/m/j sub frame [Re: 65rbdodge] #703212
05/21/10 10:19 AM
05/21/10 10:19 AM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
I put an 88 dak frame under my 57 but, i remounted the 57 cab onto the 88 dak frame. I thought this would be easier and stonger than welding up the frame at such a high stress point as right behind the motor and i put in 440-727 combo as well. You may just decide to use all dak frame , depending on how you want the bed floor to look.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: f/m/j sub frame [Re: rattler] #703213
05/21/10 10:42 AM
05/21/10 10:42 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
A while back I posted frame measurements for the 40s mopars and the dakota. It should still be in here. Lots of other threads on the dakota, both clip and full frame.
Re: f/m/j sub frame [Re: RodStRace] #703214
05/21/10 11:27 PM
05/21/10 11:27 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
the dakota trannys bolt to the bell housing from inside the bell housing not from the out side like a 1950s 60s 70s trans we are all use to,,,
some guys on other mopar boards are using toyota supra 5 speed boxes,,both made by new process and the toyota from what i have read bolts up to the dakota bell housing,, the supra tranny is stronger,, but if your not ram rodding it,,the dakota tranny may be ok,,,for a cruiser,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: f/m/j sub frame [Re: fstfish66] #703215
05/23/10 09:27 AM
05/23/10 09:27 AM
MA
Greg55_99 Offline
Greg55_99  Offline
MA
Actually, the hot ticket these days is the 2004-2010 Ford Crown Victoria front suspension:
Greg
Re: f/m/j sub frame [Re: Greg55_99] #703216
05/23/10 09:43 AM
05/23/10 09:43 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
IIRC, it's a bit wide, someone posted the specs at one time, was thinking about a certain 65 Cuda I have.
Re: f/m/j sub frame [Re: Supercuda] #703217
05/23/10 09:59 AM
05/23/10 09:59 AM
stevieh Offline OP
stevieh  Offline OP
it looks great, and easy to find, but too wide for my 48 i think, i need to stay about 58",
Re: f/m/j sub frame [Re: Greg55_99] #703218
05/24/10 08:07 AM
05/24/10 08:07 AM
A Happy Place, A Happy Place, ...
57Plymouth Offline
57Plymouth  Offline
Care to give any more reasons on the Crown Vic swap? Is the Crown Vic front end a drop out assembly like the F/M/J? Obviously from that photo you have the advantage of rack and pinion and coil springs, but what are the other benefits.
Not trying to slam you, just looking for more information about the pros and cons of the Crown Vic front end. I drove a 2006 Crown Vic last week, and I thought it rode and handled very good, but the steering was VERY light.
Virtus Junxit Mors Non Separabit
Re: f/m/j sub frame [Re: 57Plymouth] #703219
05/24/10 04:22 PM
05/24/10 04:22 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Advantages are that it's 1-piece, they are available in the JY, possibly from a lower-mileage vehicle and needing little repair. Another advantage is decent-sized disc brakes.
If my research is correct (Rock Auto), the 2003-2010 Vic has 12.01" rotors, while the 1998-2002 has 12.42" discs. Brakes got smaller as the cars got newer. The 2003+ Vic copcars have the very flat-looking wheels, and possibly there was a wider track integrated into the design. There may be other changes in the overall brake system to compensate for the now-smaller rotors, or the vehicle may have gotten lighter and not needed as much braking.
As always, don't just take my word for it. Take my word and then dig deeper to verify for yourself.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: f/m/j sub frame [Re: Fury Fan] #703220
05/24/10 06:37 PM
05/24/10 06:37 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
You may only want the K=frame..from the volere..I put it in my 1956 and it was the best think I did to the car..Four bolts and a few hoses and its out ..ALL THE PARTS ARE AVALIBLE..It gives you the disc brakes and p/s,and torsion bars...If you can ,get the whole car..I bought a 1986 Chrysler 5th ave for $ 250.00 with a blown motor and got the steering colume and master cylinder and anything else I could use..Simple install,and drives straight and smooth..
Re: f/m/j sub frame [Re: 57Plymouth] #703221
05/24/10 10:19 PM
05/24/10 10:19 PM
MA
Greg55_99 Offline
Greg55_99  Offline
MA
As has been stated, the Crown Vic front end is a complete drop out piece. The most critical width is the outside tire to outside tire distance which is 72" with the stock steel Vic Cop car wheels. If you can get that under your fenders, it can be made to work.
Lots of theads on the Ford truck board on how it's done:
http://www.ford-trucks.com/forums/934493-rusty-63s-f100-2004-cv-pi.html
http://www.ford-trucks.com/forums/756556-2007-mercury-grand-marquis-suspension-into-a-72-f100.html
http://www.ford-trucks.com/forums/716058-buildup-06-crown-vic-front-suspension-into-67-f100.html
It's a real neat piece...
Greg
Re: f/m/j sub frame [Re: 65rbdodge] #703222
05/25/10 07:52 AM
05/25/10 07:52 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
only the NVG3500's are...the smaller NVG 1500 (can't remember if those were used in 4cyl daks) and the Aisin AX15 have a separate bell
2017 Grand Cherokee Overland
