Page 2 of 3 1 2 3
Re: Mechanical advance too quick on Mopar Perf Dizzy? [Re: Chilort] #703100
05/22/10 05:16 PM
05/22/10 05:16 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
It is an auto with a bad setup for quench (pistons are .100 in the hole), which appears to be a great combo for detonation. Maybe I'll try the slightly stiffer spring tomorrow depending on rain.
What made you decide to build it this way?
Re: Mechanical advance too quick on Mopar Perf Dizzy? [Re: CRE2004] #703101
05/22/10 05:50 PM
05/22/10 05:50 PM
Cookeville
Chilort Offline OP
Will Work For Mopars
Chilort  Offline OP
Cookeville
Pistons were in the block when I got it. The pistons were pert near new. I have no idea how long ago it was rebuilt but I've owned the block for over a decade before I tore into it. It looked like it had been run low on oil. We polished the crank, new bearings, new rings, pin fit the rods, and resized the big end and put it back together. I helped in the machine shop quite a bit to keep my bill down. I'm a student (though a rather old one). The goal was to keep the price as low as possible while also purchasing any long term parts that could be reused many times (i.e. rocker assembly, heads).
The next question is "why a 440 then?" or something along those lines. That is what was in the truck when I got it and was one of the reasons I got the truck. I got it about 3 years ago so my wife and I could work on our house without having to rent a truck or pay for delivery. I could have gotten something more reasonable but that wouldn't be any fun. When the crank broke in the truck in September I decided it was best to use the block I had in storage and save the one from the truck for later (still not quite sure what went wrong, I was following a Honda minivan on a ramp onto the interstate so you know I wasn't reaming the pi$$ out of it).
I use the truck frequently as a daily driver; use it to haul lumber, yard supplies, and occasionally new appliances; never use it on the strip; and some times use it to turn rice into rice crispies.
I also have a dog and cat.
Answering these kinds of questions really doesn't solve the issue or even help anyone really learn much. It is what it is man. But some people just gotta know I guess.
Re: Mechanical advance too quick on Mopar Perf Dizzy? [Re: Chilort] #703102
05/22/10 05:52 PM
05/22/10 05:52 PM
Kirkland, Washington
Pacnorthcuda Offline
Answering these kinds of questions really doesn't solve the issue or even help anyone really learn much. But some people just gotta know I guess.
What are names of the dog and cat?
Re: Mechanical advance too quick on Mopar Perf Dizzy? [Re: Pacnorthcuda] #703103
05/22/10 10:23 PM
05/22/10 10:23 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
i would put a vacuum gauge on the carb and go for a ride and see at what vacuum you get the knock and compare that reading to the value of the power valve you are using. maybe you just need to change the power valve to match your setup.
Re: Mechanical advance too quick on Mopar Perf Dizzy? [Re: macmic87] #703104
05/23/10 11:52 AM
05/23/10 11:52 AM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
I looked up some more detailed info on the carb and it has a 21 metering plate and that works out to a 75 jet for the secondary. Additionally, the power valve is 65 and that is very close to what I would get if I were to follow Holley's instructions for sizing a power valve (halve the idle vacuum then multiply by 10). A 55 would be close too but am I that far off with the 65 to cause this issue?
Re: Mechanical advance too quick on Mopar Perf Dizzy? [Re: Chilort] #703105
05/23/10 11:55 AM
05/23/10 11:55 AM
No. The difference in throttle between 5.5 and 6.5 inches of vacuum is VERY slight--look elsewhere.
Re: Mechanical advance too quick on Mopar Perf Dizzy? [Re: Pacnorthcuda] #703106
05/23/10 12:21 PM
05/23/10 12:21 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
More infos for you..
I'm running in a 408 stroker 180 lbs cylinder pressure with RHS Iron heads .......not a sound.
Iridium plugs from NGK
Dan
Re: Mechanical advance too quick on Mopar Perf Dizzy? [Re: Wedgeman] #703107
05/24/10 02:23 PM
05/24/10 02:23 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
I went up to 74 jets today. Still has the same sound at 75mph with light application of throttle over what it takes to maintain speed on flat land. I checked the vacuum at which it wants to knock and it is 15inhg. The butt dyno has liked all of the changes so far and the 74 jets feel nice. Looking forward to checking the plugs.
Re: Mechanical advance too quick on Mopar Perf Dizzy? [Re: Chilort] #703108
05/24/10 02:36 PM
05/24/10 02:36 PM
Stick a 3/32" allen wrench in the vac can & turn it 3 turns CCW and retry it.
Re: Mechanical advance too quick on Mopar Perf Dizzy? [Re: RapidRobert] #703109
05/24/10 03:42 PM
05/24/10 03:42 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Been testing all of this without the vacuum advance hooked up.
Re: Mechanical advance too quick on Mopar Perf Dizzy? [Re: Chilort] #703110
05/25/10 11:23 AM
05/25/10 11:23 AM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Could this be a phasing issue? I've heard a lot about it but never really checked much into it.
Re: Mechanical advance too quick on Mopar Perf Dizzy? [Re: Chilort] #703111
05/27/10 09:06 PM
05/27/10 09:06 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
So I've got a few hundred miles on the colder plug with the increased jetting and it still doesn't look right to me.
I've got the total timing pulled all the way back to 32* and I've still got the same issue.
Thoughts?
Re: Mechanical advance too quick on Mopar Perf Dizzy? [Re: Chilort] #703112
05/27/10 09:15 PM
05/27/10 09:15 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
I'd say by the look of those the plugs you're getting oil in the chambers. Possibly via valley pan.
Re: Mechanical advance too quick on Mopar Perf Dizzy? [Re: ireland383] #703113
05/27/10 09:21 PM
05/27/10 09:21 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
No oil. Must be the photo. Additionally, It is a black plug and I use anti-seize when I install plugs.
Re: Mechanical advance too quick on Mopar Perf Dizzy? [Re: Chilort] #703114
05/28/10 10:16 AM
05/28/10 10:16 AM
Drill a 1/2" hole in the top flat of the cap 2/3 of the way between the center and the #1 terminals and freeze the rotor at idle w your light & see if it is way off and the rotor phasing at idle will be at it's maximum CW location (big block) from the high vacuum and less vacumm will shift it more CCW from there.
Re: Mechanical advance too quick on Mopar Perf Dizzy? [Re: RapidRobert] #703115
05/29/10 03:06 PM
05/29/10 03:06 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Phasing looks to be dead on.
Edit: Never mind. Winner is ireland383. Sucking oil.
Re: Mechanical advance too quick on Mopar Perf Dizzy? [Re: Chilort] #703116
05/29/10 09:17 PM
05/29/10 09:17 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Reinstalled intake with new gaskets and it still clatters under the same old conditions. I didn't pull any plugs yet. Too frustrated.
Re: Mechanical advance too quick on Mopar Perf Dizzy? [Re: Chilort] #703117
05/30/10 08:13 AM
05/30/10 08:13 AM
Might hook a small gas can in the eng compartment w several gallons of race gas to the pump inlet & take her out to confirm/deny that the noise is pinging or something else. Good luck bro
Re: Mechanical advance too quick on Mopar Perf Dizzy? [Re: Chilort] #703118
05/30/10 08:33 AM
05/30/10 08:33 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Could your clatter be valvetrain noise? At certain RPM'S I get a clatter. Just from the fast ramp of the cam.
Re: Mechanical advance too quick on Mopar Perf Dizzy? [Re: ireland383] #703119
05/30/10 11:28 AM
05/30/10 11:28 AM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
That's what I'm kind of thinking. Even though it is a hydraulic setup could I have put too much preload on the lifters? I think I may check the preload today or tomorrow. But I'd really like to eliminate the possibility of detonation before I give up.
I don't know where to get race gas or I'd do it today. I'll have to call the engine builder because he'll know where to get some locally. I'm not running an hour north of Atlanta to the "Atlanta" Dragway to get race gas.
I've got one more thing I'm thinking of but I don't know how it could be it. When I mated the engine and trans together the torque converter had just slightly more than 1/8" play, something like .150 IIRC. I called Paul Forte and he said all would be okay as long as the flex plate bolts weren't hitting the torque converter. It was really close. Maybe I'm getting just enough flex in something that its touching... seems far fetched though. Either way, I picked up some washers this morning and found a matched set of four to try out.
Of course my wife wants to go to an art's festival today so I'll have to suffer through that before I can try this out.
Page 2 of 3 1 2 3
