1970 V code K member bolt size #702130
05/19/10 12:20 AM
05/19/10 12:20 AM
canada
70 roadrunner Offline OP
canada
Hey gang. What is the bolt size for a 1970 440+6BBl K member? The 4 bolts that mount it to the frame rails. Thank you. Bill.
Re: 1970 V code K member bolt size [Re: 70 roadrunner] #702131
05/19/10 12:56 PM
05/19/10 12:56 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Bill, telling you the size and thread pitch of the threaded portion of those bolts will not help you. These are specialty bolts with a tapered shoulder that is important for proper positioning of the K member. The size on a V code car is the same as any other Mopar of that era. You need to shop for a set of good used or reproduction K MEMBER BOLTS. There is often a member or two with them here on the parts for sale pages, and failing that, on ebag or Amazon.
As a matter of fact, I am surprised that you did not yet get an offer to sell you some, based solely on your question.
Down to just a blue car now.
Re: 1970 V code K member bolt size [Re: 68HemiB] #702132
05/19/10 01:11 PM
05/19/10 01:11 PM
Re: 1970 V code K member bolt size #702133
05/19/10 03:24 PM
05/19/10 03:24 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
http://www.bmcuda.com/proddetail.asp?prod=2467693
RobX4406 probably has a set that he will sell for substantially less than $45.
Re: 1970 V code K member bolt size [Re: 68HemiB] #702134
05/19/10 05:06 PM
05/19/10 05:06 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
I've got k member bolts that can be had cheap if you need them. PM me..if you need help.
-M
Re: 1970 V code K member bolt size [Re: 70 roadrunner] #702135
05/19/10 06:19 PM
05/19/10 06:19 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
The same ones that bolt a 70 /6 k-member in or any other k-member nothing special...
Re: 1970 V code K member bolt size [Re: QuickBpBp] #702136
05/20/10 11:28 AM
05/20/10 11:28 AM
canada
canada
Thanks for all the tips, info etc gang. My father had them in the top shelf of his tool box..Had to move the car yesterday to a new garage. Thanks again. Bill.
