what motor would you turbo? #701061
05/18/10 12:53 AM
05/18/10 12:53 AM
Carstairs, Alberta, Canada
dave571 Offline OP
dave571  Offline OP
I'm planning out a turbo for my 74 club cab dually.
Automatic. Will be used for regular driving, and some hauling.
The truck is set up for a big block already, and I have 2 motors that are prime candidates.
Both are stockers, unmolested, and run awesome, with no smoke or ticking. Kinda cool.
1)76 400. it's out of a cordoba/charger. untouched, with the tq still on. 452's yadda yadda yadda
2)69 383 2bbl. Also untouched, 906's, and runs smooth as glass.
With eiher one, My plan was/is to leave the motor as stock as possible. Basic intake and carb change to match the turbo. A small turbo for quick spooling(torque is goal more than all out power). Intercooler to keep it from pinging under load, etc..
My debate is, does the larger displacement of the 400, and lower compression ratio, make it clearly more desirable for this build?(I agree it should make better power) OR does the steel crank and the still pretty low comp a 2bbl 383 has make it the better choice?
Both are in mine already, so there is no money involved.
I'v measured 400's to typically be around 7.5:1 compression. I measured a 68 2 bbl 383 once, and it was on the low 8's, so I would expect this 69 to be similiar.
Any input appreciated
Re: what motor would you turbo? [Re: dave571] #701062
05/18/10 03:21 AM
05/18/10 03:21 AM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
I'd probably build the 383, just for the crank. I built a 318 instead of a 360, for the same reason. The little bit more compression may help the truck with pep at low RPM's as well. 7.5 is really low, even for boosted applications.
Put a performer on it with a 650-750 DP, blowthrough mod it, mild camshaft, surface the heads and use good gaskets. Theres a guy on theturboforums (and maybe here?) that goes by CW25 that did something pretty similar I believe.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: what motor would you turbo? [Re: topfueldart] #701063
05/18/10 11:33 PM
05/18/10 11:33 PM
St.Louis ,Mo.
72sat Offline
72sat  Offline
St.Louis ,Mo.
400 has lower comp & bigger dia. pistons.It also has better heads(452).906s need to be ported & hard seats installed.both have cast pistons.steel crank does not matter because you are not going for max boost with cast pistons.No detonation,this will kill cast pistons.
Re: what motor would you turbo? [Re: 72sat] #701064
05/19/10 08:25 AM
05/19/10 08:25 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
I would build the 400 for the same reasons as above.
Re: what motor would you turbo? [Re: TheOtherDodge] #701065
05/19/10 08:43 AM
05/19/10 08:43 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
400.
Coming soon!!!!
Re: what motor would you turbo? [Re: Mr.Yuck] #701066
05/19/10 09:03 AM
05/19/10 09:03 AM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
Boost the 383 now and use the 400 for a real build! Strength is moot for a low boost application. The 383 might provide better non boost drivability with more comp.
Re: what motor would you turbo? [Re: Shaker223] #701067
05/19/10 09:05 AM
05/19/10 09:05 AM
Houston, Texas
Houston, Texas
Get the correct size turbo and there will be very little turbo lag.
Re: what motor would you turbo? [Re: 72sat] #701068
05/19/10 10:11 AM
05/19/10 10:11 AM
Pasagetdowndena
Cranky Offline
Cranky  Offline
Pasagetdowndena
How much difference are the ports between the 452's and the 906's?
Well, I'll tell ya...there's not enough difference between the ports of the two head to worry about but the good part about the 452's is that they have the hardened valve seats already...not that I ever sunk a valve in 906's.
Re: what motor would you turbo? [Re: Cranky] #701069
05/20/10 02:39 PM
05/20/10 02:39 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
For a low-boost application in a truck I think either one on paper will be too similar to make a difference.
I would do a leakdown check and use whichever one seals better. Oil leakage into the combustion chamber leads to detonation.
OTH, I read somewhere that everyone destroys their first home-built turbo, so use whichever engine you like least.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: what motor would you turbo? [Re: Fury Fan] #701070
05/20/10 04:45 PM
05/20/10 04:45 PM
Houston, Texas
Houston, Texas
"I read somewhere that everyone destroys their first home-built turbo"
Better not be true!
Re: what motor would you turbo? [Re: TheOtherDodge] #701071
05/20/10 08:16 PM
05/20/10 08:16 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Better not be true!
Mine made it through the dyno session.....thats a start i hope, but i read the same thing
Re: what motor would you turbo? [Re: TheOtherDodge] #701072
05/21/10 09:37 AM
05/21/10 09:37 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Better not be true!
Would it be better if he said everybody drives their first turbo into the wall?
- Stu Harmon
Re: what motor would you turbo? [Re: feets] #701073
05/21/10 12:36 PM
05/21/10 12:36 PM
Chicago, Illinois
donscuda Offline
donscuda  Offline
Chicago, Illinois
Not really......
Re: what motor would you turbo? [Re: donscuda] #701074
05/21/10 04:48 PM
05/21/10 04:48 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Not really......
TheOtherCamaro has a special place in his heart for that statement.
I guess it's time for a new name.
TheOtherS10?
TheOtherDakota?
- Stu Harmon
Re: what motor would you turbo? [Re: feets] #701075
05/23/10 06:04 PM
05/23/10 06:04 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Better not be true!
OUCH!!! That will smart...lol.
Re: what motor would you turbo? [Re: Quicksilver440] #701076
05/23/10 10:48 PM
05/23/10 10:48 PM
IN
ahy Offline
ahy  Offline
IN
I guess I'd turbo the 383 with the heads from the 400. That gives you the forged crank and hardened seats. For your build, the few cubes difference won't matter and that saves the 400 block for your second engine.
Re: what motor would you turbo? [Re: ahy] #701077
05/24/10 10:15 PM
05/24/10 10:15 PM
dave571 Offline OP
dave571  Offline OP
All interesting points, guys. Thanks
I'm not sure which I like least. I'm hoping when I get down to the build itself, I'll get enough info fom reliable spources, that I won't grenade it. We'll see
Re: what motor would you turbo? [Re: dave571] #701078
05/25/10 03:43 PM
05/25/10 03:43 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
My first turbo has survived so far. I hope to freshen it up before it lets go lol
Re: what motor would you turbo? [Re: ahy] #701079
05/26/10 11:28 PM
05/26/10 11:28 PM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
That is exactly what I did but the large 452 chambers made for 7.4:1 compression. That makes for pretty soggy low end power. Had to crank up the boost to 15 psi but made 450+ HP with a basicly stock 383. Built the 400 with a stock 383 crank and 9:1 compression. It is a terror on the street and drives as super good.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
