indy intake ? #700313
05/17/10 10:17 AM
05/17/10 10:17 AM
Ky
moparmafia Offline OP
Ky
i have a chance to buy a used indy lowdeck intake at a good price that has the dominator flange. i have been told there is a power loss using it versus the standard 4150 flange with adapter. has anyone done this swap before to know for sure? i was told there is a tenth difference at the track. i am building a 500 inch roller motor for track only. thanks for any input.
Re: indy intake ? [Re: moparmafia] #700314
05/17/10 10:54 AM
05/17/10 10:54 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The low deck Dominator flange his some minor drawbacks that can easily be rectified.The runner dividers need to be cut back and a 2" riser added and it will work quite well.The 4150 flanged manifold works well with a 2"4500 adapter and usually shows about a 10 to 15 hp gain on a dyno.Modifying the Dominator flange manifold will gain you the same if not more.
Re: indy intake ? [Re: B G Racing] #700315
05/17/10 12:26 PM
05/17/10 12:26 PM
Cab_Burge Online work
Cab_Burge  Online Work
The spacer versus the adapter makes the phenlum volume almost the same on both set ups, not using the spacer makes the 4500 intake not make as much power as the 4150 intake with the 4500 adapter due to less phenlum volume
