I have the blue point version of this light and love it, been using it for years as my go-to since it's 1 wire, but I can attest it does work well with my set up. (6al and now digital-6)
I also have a MAC dial back light that I use for when I want to dial in total advance and a couple craftsman el-cheapos to check against and all are accurate to each other.
Flaming River 40.00 uses two D cells and one wire on plug .no other wires needed
Same one here... best light I have used and I have a
few of them... MSD can be touchy due to its multi
spark under 3000 rpm.... plus the Flaming River uses
the 2 D-cell you dont need the power hook up which
is easier and faster
