Re: B Body rear defogger defroster [Re: autoxcuda] #700099
05/19/10 10:36 PM
05/19/10 10:36 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The thing that looks like a heater element is the blower motor resistor.
Yes it's a resistor, not a heater element(although that would have been more useful I bet). Some have the resistor, most don't. I have one of each sitting around. Did the resistor-equiped ones have a 2-speed switch for the defogger or where they just setup with the resistor to lower fan speed to keep the noise down?
Re: B Body rear defogger defroster [Re: DaytonaTurbo] #700100
05/19/10 10:54 PM
05/19/10 10:54 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Mine just has on/off.
Re: B Body rear defogger defroster [Re: DaytonaTurbo] #700101
05/20/10 01:39 AM
05/20/10 01:39 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
resistor units are since 70... to set a lower speed from the switch
Re: B Body rear defogger defroster [Re: 318 Stroker] #700102
05/20/10 02:43 AM
05/20/10 02:43 AM
US of A
A38s! Offline
A38s!  Offline
US of A
AFAIK, that adapter will work in any application that has a 6" x 9" speaker hole. The only one that might be a problem is if the 6" x 9" hole you want to use it on goes lengthwise to the car instead of side-to side. You may run into a clearance problem fitting in the speaker & the defog motor.
I believe there was only one adapter made, and it worked in all bodies.
Makes sense. This particular unit is from a 72 Polara, 2-speed switch (with resistor). 6x9 holes run side-side (thought they all did), with the blower oriented further into the trunk.
With 3 mounting points, the 3rd is offset 1.5".
WANTED: Your 71-78 Late B-body sedan parts! Police or Civilian.
Re: B Body rear defogger defroster [Re: tt455] #700103
05/20/10 02:51 AM
05/20/10 02:51 AM
US of A
A38s! Offline
A38s!  Offline
US of A
Re: B Body rear defogger defroster [Re: Scott Carl] #700104
06/01/10 05:01 PM
06/01/10 05:01 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
I was wrong Just looked again. It does, in deed, have a hi/lo switch.
Re: B Body rear defogger defroster [Re: Scott Carl] #700105
06/01/10 06:41 PM
06/01/10 06:41 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
My '73 Roadrunner had one, it was missing. I am replacing it, and running one speaker front, one speaker rear. I found the parts locally. The car sounds so good I could care less about tunes, and I figure with A/C that rear fan moving air around will help make the inside like a freezer! My other cars have tunes, so I thought it would be cool to make it as original as I can. Doubt I could hear the AM stereo over the engine anyway, unless the car is parked............
Re: B Body rear defogger defroster [Re: 4BBodies] #700106
06/01/10 06:44 PM
06/01/10 06:44 PM
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
I have a question, what was used as a bezel or screen? The donor car I got the unit from had nothing over the intake.
Re: B Body rear defogger defroster [Re: 4BBodies] #700107
06/02/10 12:51 AM
06/02/10 12:51 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
71/74 Bs are without anything but the speaker grill cuts on the tray package. Not bezel or screen
Re: B Body rear defogger defroster [Re: tt455] #700108
06/03/10 10:17 PM
06/03/10 10:17 PM
dougc426 Offline
dougc426  Offline
hey guys,I have a 1969 dodge charger.It came with a rear speaker system(but)not with dual rear speakers,The way i read the 1969 parts book it came with such a system.But the housing you show will not fit a charger with dual rear speakers as the hump under the package tray is in the way.so i have a housing that came from a c body that i will modify to fit,any help out there guys???...Thanks...Doug
