I recently purchased a 1970 challenger with a 383 and automatic transmission. It was converted from a 2-barrel to a 4-barrel at some point. It was not running when I bought it and after spending some time I finally am able to drive it. The transmission does not seem right however. It does not shift to 2nd until about 25 mph and it shifts hard. It does not shift to 3rd until about 50. This is under light throttle. The throttle pressure linkage is a one piece model but it seems to be moving ok. Does the trans need rebuilding or some type of adjustment?
Thanks for any assistance.
