Page 2 of 3 1 2 3
Re: Electric fuel pump location [Re: W5Duster436] #694903
05/11/10 09:27 PM
05/11/10 09:27 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I just mount a holley blue pump on my barracuda. I made a bracket that hangs dwon from the shock studs. I made it out of 3/4" square tube the pump is even with the bottom of the tank ans sits in front of the tank right to the drivers side of the center section of the rearend hosing
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Electric fuel pump location [Re: W5Duster436] #694904
05/11/10 09:48 PM
05/11/10 09:48 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Looks good Kyle.
Hope it works well and feeds that monster.
Re: Electric fuel pump location [Re: W5Duster436] #694905
05/11/10 11:06 PM
05/11/10 11:06 PM
That looks good I'm sorry for the picture not working earlier
Re: Electric fuel pump location [Re: Cab_Burge] #694906
06/28/10 01:16 PM
06/28/10 01:16 PM
Indiana
W5Duster436 Offline OP
Indiana
So at my wits end now. This setup is not working either. Pump appears to cavitate or vapor lock etc. After everything warms up my fuel pressure will go whacko and bounce around a little then it'll go to about 2-3 psi and then finally putz out. I moved the front fuel filter from the connection at the factory up to the regulator directly off the carb thinking maybe the headers may have gotten the fuel boiling. This made no difference either. The only other thing that makes me wonder is that this fuel tank originally was ecs and I changed it over to non-ecs and it only has the small 1/4" or whatever air vent off the fill tube. I also put a vented locking gas cap as I didn't have the correct non-ecs cap. So it should have enough vent but maybe not? I'll post some pictures of basically the whole setup in a minute. Any ideas what else could cause this?
Maybe having the reg by the intake etc is causing it as well? See below pics and see if anything stands out that could be a problem.
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
Re: Electric fuel pump location [Re: W5Duster436] #694907
06/28/10 01:25 PM
06/28/10 01:25 PM
Indiana
Indiana
#1
'71 Dodge D100
'70 Dodge W100
Re: Electric fuel pump location [Re: W5Duster436] #694908
06/28/10 01:26 PM
06/28/10 01:26 PM
Indiana
Indiana
#2
'71 Dodge D100
'70 Dodge W100
Re: Electric fuel pump location [Re: W5Duster436] #694909
06/28/10 01:26 PM
06/28/10 01:26 PM
Indiana
Indiana
#3
'71 Dodge D100
'70 Dodge W100
Re: Electric fuel pump location [Re: W5Duster436] #694910
06/28/10 01:27 PM
06/28/10 01:27 PM
Indiana
Indiana
#4
'71 Dodge D100
'70 Dodge W100
Re: Electric fuel pump location [Re: W5Duster436] #694911
06/28/10 01:27 PM
06/28/10 01:27 PM
Indiana
Indiana
#5
'71 Dodge D100
'70 Dodge W100
Re: Electric fuel pump location [Re: W5Duster436] #694912
06/28/10 01:28 PM
06/28/10 01:28 PM
Indiana
Indiana
#6
'71 Dodge D100
'70 Dodge W100
Re: Electric fuel pump location [Re: W5Duster436] #694913
06/28/10 01:28 PM
06/28/10 01:28 PM
Indiana
Indiana
#7
'71 Dodge D100
'70 Dodge W100
Re: Electric fuel pump location [Re: W5Duster436] #694914
06/28/10 01:28 PM
06/28/10 01:28 PM
Indiana
Indiana
#8
'71 Dodge D100
'70 Dodge W100
Re: Electric fuel pump location [Re: W5Duster436] #694915
06/28/10 01:29 PM
06/28/10 01:29 PM
Indiana
Indiana
#9
'71 Dodge D100
'70 Dodge W100
Re: Electric fuel pump location [Re: W5Duster436] #694916
06/28/10 01:29 PM
06/28/10 01:29 PM
Indiana
Indiana
#10
'71 Dodge D100
'70 Dodge W100
Re: Electric fuel pump location [Re: W5Duster436] #694917
06/28/10 01:30 PM
06/28/10 01:30 PM
Indiana
Indiana
#11
'71 Dodge D100
'70 Dodge W100
Re: Electric fuel pump location [Re: W5Duster436] #694918
06/28/10 01:30 PM
06/28/10 01:30 PM
Indiana
Indiana
#12
'71 Dodge D100
'70 Dodge W100
Re: Electric fuel pump location [Re: W5Duster436] #694919
06/28/10 01:31 PM
06/28/10 01:31 PM
Indiana
Indiana
#13
'71 Dodge D100
'70 Dodge W100
Re: Electric fuel pump location [Re: W5Duster436] #694920
06/28/10 01:32 PM
06/28/10 01:32 PM
Indiana
Indiana
#14
'71 Dodge D100
'70 Dodge W100
Re: Electric fuel pump location [Re: W5Duster436] #694921
06/28/10 01:32 PM
06/28/10 01:32 PM
Indiana
Indiana
#15
'71 Dodge D100
'70 Dodge W100
Re: Electric fuel pump location [Re: W5Duster436] #694922
06/28/10 01:33 PM
06/28/10 01:33 PM
Indiana
Indiana
#16
'71 Dodge D100
'70 Dodge W100
Page 2 of 3 1 2 3
