rear diff noise pinion angle #693378
05/09/10 07:51 PM
05/09/10 07:51 PM
Harrisburg Pa. 17112
moparmikethree Offline OP
I have a noise in my 8 3/4 rear when accelerating as soon as i let off the noise goes away. Someone
said it may be the angle of the rear?
Re: rear diff noise pinion angle [Re: moparmikethree] #693379
05/09/10 09:03 PM
05/09/10 09:03 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Pinion angle doesn't make noise. It will cause a shudder or vibration under load, but generally not a noise.
A loose pinion may make a noise. Gear wear, etc..
Re: rear diff noise pinion angle [Re: moparmikethree] #693380
05/09/10 09:38 PM
05/09/10 09:38 PM
NE
moparpoolman Offline
NE
Sounds like a bad U joint.
Re: rear diff noise pinion angle [Re: moparpoolman] #693381
05/11/10 11:21 AM
05/11/10 11:21 AM
Maryland, USA,
satgtx Offline
satgtx  Offline
Maryland, USA,
My 3:55's have been makeing a howling noise for 25 years. never had a problem though, what gears?
Re: rear diff noise pinion angle [Re: satgtx] #693382
05/20/10 10:33 PM
05/20/10 10:33 PM
gears are 3;91's
Only started since I removed the
wedges under axle and leaf springs.
Re: rear diff noise pinion angle [Re: moparmikethree] #693383
05/20/10 10:37 PM
05/20/10 10:37 PM
hobbs, new mexico
SixDRacing Offline
SixDRacing  Offline
hobbs, new mexico
describe the noise.
Re: rear diff noise pinion angle [Re: moparmikethree] #693384
05/20/10 11:18 PM
05/20/10 11:18 PM
Newfoundland Canada
Mopar1 Offline
Mopar1  Offline
Newfoundland Canada
Sounds like it could be a side bearing.
Re: rear diff noise pinion angle [Re: Mopar1] #693385
05/20/10 11:35 PM
05/20/10 11:35 PM
a whining noise when accelerating , goes away when letting off of the gas. (like in the Jeep Cherokee's)
Re: rear diff noise pinion angle [Re: moparmikethree] #693386
05/21/10 08:39 AM
05/21/10 08:39 AM
hobbs, new mexico
SixDRacing Offline
SixDRacing  Offline
hobbs, new mexico
whining under power- to much backlash. are they new gears? if gears are old, they are worn enough to create the noise. if new, they were set up thet way.
