Rear End help (weird question!!!!) #693052
05/09/10 11:23 AM
05/09/10 11:23 AM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
When my car sits for a few days the rear end fluid some how flows up the vent tube drips on the floor. My vent tube runs up to the floor board and has a filter mounted on the end. I've checked the fluid level several times and it is not overfilled. This only happens when the car sits for 5 days to a week. Any ideas?
Re: Rear End help (weird question!!!!) [Re: gsmopar] #693053
05/09/10 12:42 PM
05/09/10 12:42 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Are you using 2 1/2 quarts of lube?
If the fluid is level with the fill plug, you are running too much.
