Racing Radiators for filled blocks, Help Needed........
#692892
05/08/10 11:55 PM
05/08/10 11:55 PM
Posts: 577 Arkansas
Adrielp
Arkansas
Okay guys, we have been using a stock radiator for some time and it has done a very good job cooling with 1inch, 2row core. Now that we have a filled block, we want to ensure that we get proper and efficient cooling for our bracket engine.
Does anyone have any suggestions for a good racing radiator that we should use for an A-body big block mopar? Price wise, what are the best options available?
Thanks in advance for comments!
Adriel Paradise Substation Design Engineer III
Re: Racing Radiators for filled blocks, Help Needed........
[Re: Adrielp]
#692895
05/09/10 09:13 AM
05/09/10 09:13 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Exactly as BobR states. You have actually reduced the demands of the cooling system. Radiator choice isnt very critical in that situation.
Get a decent radiator and a better oil cooler.
RIP Monte Smith
[Re: smokinwoody]
#692896
05/09/10 09:41 AM
05/09/10 09:41 AM
quick77rt
Parts Problem
Parts Problem
mine is a 31x19 dual pass aluminum and I use dual Spal fans... Same as mine, never a over heat issue. If its street driven go for the oil cooler, with my half fill my oil gets hot and thin and I notice the hardblock holds alot of heat...its the only areas on my block that the high heat paint wont stay on. Do yourself and your motor a favor...oil cooler. Quote:
Northern Radiators...Jegs or Summit has them I believe under their brand...
I bought mine off a fellow that sells them on Ebay...
Post deleted by Defbob
[Re: CompWedgeEngines]
#692897
05/09/10 12:25 PM
05/09/10 12:25 PM
#692898
05/09/10 02:12 PM
05/09/10 02:12 PM
Posts: 577 Arkansas
Adrielp
Arkansas
Thanks guys, I guess I can start shopping for a good oil cooler instead. Any suggestions on those?
