Hooking W/Leaf Springs
#692822
05/08/10 10:41 PM
05/08/10 10:41 PM
Posts: 1,532 off the grid
340B5
off the grid
I seem to need a little more hook for slick track conditions, I'm thinking; 1. Clamp front of leaf springs 2. More front end travel 3. Solid spring eyes 4. Calvert shocks vs my CE 3-way (set 90/10) 5. All of the above? Just would like to gather thoughts before going at it. Thanks, Mike
Yeah, it's got a smallblock.
Post deleted by Defbob
[Re: 340B5]
#692823
05/08/10 10:57 PM
05/08/10 10:57 PM
Re: Hooking W/Leaf Springs
#692824
05/08/10 11:08 PM
05/08/10 11:08 PM
90% of making one hook is in the front end........It needs to be really loose with loose shocks (I've had good luck with Cal-Trac shocks myself)......I like to use poly lower control arm bushings, heim joint strut rods, and heim joint upper control arms......and then shoot for 5" of travel from rest to all the way up........ After the front end is taken care of, I like to run a pretty stiff set of leaf springs....the faster the car, the stiffer.......and as you mentioned, clamps on the front halfs along with good adjustable rear shocks so you can control body seperation........I shoot to have just enough body seperation that you can just see the body move away from the wheel about an inch......If it seperates more than that with the shock on the tightest setting, it's time to start adding clamps onto the rear spring halves...... The worse the track is, the looser the shocks will need to be to get that 1" of seperation.......and, obviously, the better the track, the tighter the shocks will need to be..... Wayne
#692825
05/08/10 11:39 PM
05/08/10 11:39 PM
340B5
off the grid
Thanks, I'm starting to get it figured out now. Originally, I had taken the rear clamps off of the SS springs and it hooked better then, but I've added a few HP/TQ over the winter. I'm thinking it's time to put the clamps back on the rear, make some for the front halves, and get some more front end travel for starters. Calvert shocks seem like a good idea.
[Re: 340B5]
#692826
05/09/10 12:12 AM
05/09/10 12:12 AM
I saw nylon front spring eye bushings for Mopar springs in the Speedway roundy pounder catalog the other day. Would these work well with a street car with SS springs under the back?
[Re: 340B5]
#692827
05/09/10 12:16 AM
05/09/10 12:16 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You should have it set up for the bad tracks and just need to adjust the shocks (both front and rear) for the good tracks.... dought you should have to clamp the rear segments
[Re: cheapstreetdustr]
#692830
05/09/10 04:09 PM
05/09/10 04:09 PM
Posts: 11,708 Portage,michigan
B3422W5
Portage,michigan
i had no problems hooking my old car with leafs anywhere, using ce 3 ways all around.
as was said, front end travel is important.
i would try cranking the torsion bars up in front if you havent already, that made a huge difference on mine, going 9.80's with 1.34 best 60 foot.
it seemed the more power you make, the easier this was to do.
start out with about 1/2 inch higher and see what happens. i would adjust mine to set evenly on each side with me in the car, using 2 guys.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#692831
05/09/10 05:12 PM
05/09/10 05:12 PM
340B5
off the grid
Thanks... all good ideas..once again, Moparts your kung fu is strong! This all comes from an exceptionally bad day at the track(60 ft wise) It had been raining for days up until a couple days before the test and tune. This was at Gateway (St. Louis), and the track was prepped for the pros. It always seems slick after that and when it rains and moisture comes up through the track. It didn't help that I did a picture perfect burnout, only to have to wait for a smokin' pukin' Ford to clear the track. Nonetheless, I've been thinking of working on 60' for a while. Last time around, I just shortened the collectors, moving torque away from bottom end. Really don't want to take the easy out again.
