1969 383, 1975 water pump housing, leaking hole. #692722
05/08/10 09:35 PM
05/08/10 09:35 PM
Mansfield, PA
thawarden Offline OP
Mansfield, PA
I have an interesting issue. If you're looking at the water pump housing on the passenger side of the engine, there are 2 mounting bolts, and in between those 2 bolts, recessed in a little, is another hole for another bolt. I missed this when assembling the engine, and now its leaking coolant when trying to fill the system. I can't for the life of me remember taking a bolt out of that hole, and I don't have a bolt that seems to fit. I have tried 5/16 of various lengths and it just slops around in the hole. 3/8 seems to be too big. Any ideas?
Any help appreciated, thanks!
--Paul
Re: 1969 383, 1975 water pump housing, leaking hole. [Re: thawarden] #692723
05/08/10 09:42 PM
05/08/10 09:42 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
It is 3/8". Run a tap in there if you have to.
Re: 1969 383, 1975 water pump housing, leaking hole. [Re: 446acuda] #692724
05/08/10 09:46 PM
05/08/10 09:46 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Big block housings have 6 bolts--3 on each side.
They are all the same thread size.
These holes go into the water jacket, so you will never seal it without the bolt in there...
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: 1969 383, 1975 water pump housing, leaking hole. [Re: wingman] #692725
05/08/10 09:54 PM
05/08/10 09:54 PM
Mansfield, PA
Mansfield, PA
Right, each side of the housing has its 3 mounting bolts, but there is another hole between the 2 top mounting bolts on the passenger side of the engine. See picture.
Re: 1969 383, 1975 water pump housing, leaking hole. [Re: thawarden] #692726
05/08/10 09:58 PM
05/08/10 09:58 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
That hole is where the water temp sensor screws in.
Then a wire attaches to make your temp guage work
Re: 1969 383, 1975 water pump housing, leaking hole. [Re: wingman] #692727
05/08/10 10:00 PM
05/08/10 10:00 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
put a temp sensor in there or a 1/8" (I think)pipe thread plug
Re: 1969 383, 1975 water pump housing, leaking hole. [Re: 446acuda] #692728
05/08/10 10:05 PM
05/08/10 10:05 PM
Mansfield, PA
Mansfield, PA
Gotcha, I put the temp sensor in the top, right next to the one heater hose nipple, didn't even notice that hole there until it started spewing coolant. So the 1/8 pipe plug it shall be
Thanks!
Re: 1969 383, 1975 water pump housing, leaking hole. [Re: thawarden] #692729
05/08/10 10:13 PM
05/08/10 10:13 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
There's still 3 bolts on that side of pump housing, so if you only installed two, you are still one short.
Re: 1969 383, 1975 water pump housing, leaking hole. [Re: buildanother] #692730
05/08/10 11:04 PM
05/08/10 11:04 PM
Mansfield, PA
Mansfield, PA
I know, all 6 of my water pump housing bolts are installed, and not leaking. I missed the hole for the sensor because I had installed it with one of the holes on top of the housing. I got the hole tapped, and plugged with an 1/8 pipe plug.
Thanks for the help guys!
--Paul
Re: 1969 383, 1975 water pump housing, leaking hole. [Re: wingman] #692731
05/09/10 07:28 PM
05/09/10 07:28 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
None of those 6 holes go into the water jacket , the top top are thru holes and the bottom 4 are blind .
