will it run 6.70? "update" 6.54
#692356
05/08/10 03:21 PM
05/08/10 03:21 PM
Posts: 2,119 sc
tjmarcus1
sc
do you think it will run a 6.7 in the 1/8? here's the deal. a friend/customer wanted me to do a street pump gas motor for his 4000lb. 73rr that he could cruise anywhere, be very low maint., and take it to the track on sat. so we chose a 505 with stealth heads, not cut-87cc. a 242/246 hyd. flat tappet cam. i put a victor intake and an 850dp on it. AFTER the plan was made he decides to put it in a back half scamp with too much gear 4.89's. also it will be a true footbrake car with a GLIDE. i figure it won't want to turn more that 5500? think it will run close to 6.70?
Re: will it run 6.70?
[Re: tjmarcus1]
#692357
05/08/10 03:25 PM
05/08/10 03:25 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Close, I run a pump gas 505 about the same 4.56 gear, stick shifted , runs 6.50 in the 1/8th but I shift at 6800
[Re: rowin4]
#692358
05/08/10 03:27 PM
05/08/10 03:27 PM
Posts: 2,119 sc
tjmarcus1
sc
is that with a hyd. flat tappet?
[Re: tjmarcus1]
#692359
05/08/10 03:28 PM
05/08/10 03:28 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Whats the scamp weigh? Converter stall? 6.70's might be pushing it. The camshaft is leaving alot on the table.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: topfueldart]
#692360
05/08/10 03:30 PM
05/08/10 03:30 PM
Quicktree
[Re: topfueldart]
#692361
05/08/10 03:31 PM
05/08/10 03:31 PM
Posts: 2,119 sc
tjmarcus1
sc
weighs about 2950. the glide and conv. came with the car. but i had ptc tighten it up, not sure what it will flash.
[Re: tjmarcus1]
#692362
05/08/10 04:43 PM
05/08/10 04:43 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
fwiw my duster weighs 3410 it has a 400rwhp 368" smallblock in it with a 175 shot no2 pill.. it runs 6.67 in the eight.with too much converter..(ptc 5200 for motor only) 727 and 4.56 gear shifting at 6400rpm fwiw... if your close to 575 hp..id say yes....
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: cheapstreetdustr]
#692363
05/08/10 05:07 PM
05/08/10 05:07 PM
Quicktree
he's talking about a 4000lb B-Body, don't think 575hp will get it to 6.70s
[Re: Quicktree]
#692364
05/08/10 05:23 PM
05/08/10 05:23 PM
Posts: 2,119 sc
tjmarcus1
sc
no, it was going in a 4000lb. rr now it's in the scamp
[Re: tjmarcus1]
#692365
05/08/10 08:04 PM
05/08/10 08:04 PM
Quicktree
ok I see, should be able to do it then.
