540" short block #691776
05/07/10 08:21 PM
05/07/10 08:21 PM
Dana Point, CA
Fast Yeti Offline OP
Dana Point, CA
I decided to have Muscle Motors build me a new 540" short block. I recently bought a new hemi ram truck and sold my daily driver. the money from the car I sold is to be used for motor upgrades. I am going to sell my 496" short block. I plan on useing as much of the top end as possible. the EZs are fully ported an will get a bigger valve to help with flow. I know these heads will not get me the most power but it fits in the budget right now. I hope to get 800 or so hp with this combination. this will be a high compression motor with a big roller cam. this is all going into a new World aluminum block. the Roadrunner should weigh around 3400lbs with me in it with the new block. I hope to be running mid 9s with this combo. I need to go to a 4.56 gear from the 4.10 and either loosen my existing converter or maybe have to go to an 8" converter. I presently have a Dynamic 9.5' 4200 stall. I will keep you informed as things progress.
Re: 540" short block [Re: Fast Yeti] #691777
05/07/10 08:31 PM
05/07/10 08:31 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Sounds awesome Tom! An 8" may be too loose for the nitrous if you're still gonna run it.
Re: 540" short block [Re: Fast Yeti] #691778
05/07/10 08:33 PM
05/07/10 08:33 PM
AndyF Offline
AndyF  Offline
EZ heads will make 800 hp on a good short block without too much trouble. Just need a good rocker arm package so you can run a good roller cam.
From the tech archive page: http://www.moparmusclemagazine.com/techa...ware/index.html
Re: 540" short block [Re: ProSport] #691779
05/07/10 08:34 PM
05/07/10 08:34 PM
Dana Point, CA
Dana Point, CA
Thanks Bob. I am going ro run all motor no N2o.
Re: 540" short block [Re: AndyF] #691780
05/07/10 08:41 PM
05/07/10 08:41 PM
Dana Point, CA
Dana Point, CA
Thanks Andy. I have Harland sharp rockers. they are only 1.5 I think they should be ok.
Good book Andy. I bought it a few months ago. Great info.
Re: 540" short block [Re: Fast Yeti] #691781
05/07/10 09:44 PM
05/07/10 09:44 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Sounds real interesting let us know how it goes.
Russ
Re: 540" short block [Re: Fast Yeti] #691782
05/07/10 10:22 PM
05/07/10 10:22 PM
NC
440Jim Offline
440Jim  Offline
NC
I decided to have Muscle Motors build me a new 540" short block. ...
I am going to sell my 496" short block. ...
I need to go to a 4.56 gear from the 4.10 ...
I don't understand why you would take the 4.10 gear out. What size slicks are you running?
I would think 9.0 and 150 mph could be close with the right head porting. I don't even have a roller cam in my 511.
Re: 540" short block [Re: 440Jim] #691783
05/07/10 10:30 PM
05/07/10 10:30 PM
ill
dennismopar73 Offline
ill
ecause shoulnt run big rpm with that long arm
Re: 540" short block [Re: 440Jim] #691784
05/07/10 11:15 PM
05/07/10 11:15 PM
Dana Point, CA
Dana Point, CA
Jim I was running a 315/60 drag radial approx. 30" tall. I recently switched to 31x16.5 QTP that are 31" tall and will have some growth. I should trap at 7300 rpms in the 1/4. my 496" set up was a street/strip combo; pump gas and I used nitrous at the track so the 4.10 worked well. Now I am going to run all motor with a taller tire and the 4.56 seems to be best for wringing everything out of this combo.
Re: 540" short block [Re: Fast Yeti] #691785
05/07/10 11:27 PM
05/07/10 11:27 PM
gregsdart Offline
gregsdart  Offline
I follow what the others say, you might want to try the converter and gears you have. The motor might like to shift at 6700 with a big rollercam, 280+ intake duration at .050, and may be OK with your converter, or maybe loosen it up some.
Re: 540" short block [Re: gregsdart] #691786
05/07/10 11:38 PM
05/07/10 11:38 PM
Dana Point, CA
Dana Point, CA
Thanks Greg. I also see what others are saying. I haven't bought any gears. I figured I would wait for the dyno sheet to see what changes to the converter need to be done if any. Mike at MM said with my EZ heads I will probably have to turn some RPM in order to make the power I hope to make.
Re: 540" short block [Re: Fast Yeti] #691787
05/08/10 05:55 AM
05/08/10 05:55 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
So, What are you doing with the old short block ??
Re: 540" short block [Re: 69CHARGERMD] #691788
05/08/10 06:15 AM
05/08/10 06:15 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
he's selling it Doug...
Re: 540" short block [Re: smokinwoody] #691789
05/08/10 07:20 AM
05/08/10 07:20 AM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Nice Tom
Sounds like you will be in for some bumper draggin fun when you get that finshed up.
Re: 540" short block [Re: Fast Yeti] #691790
05/08/10 07:45 AM
05/08/10 07:45 AM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Sounds like a great plan Tom !
Will you have it at Norwalk this september ?
Ron
Re: 540" short block [Re: 340RICK] #691791
05/08/10 07:46 AM
05/08/10 07:46 AM
Dana Point, CA
Dana Point, CA
Thanks guys. I am selling the short block. If anyone is interested they can pm me.
Re: 540" short block [Re: Fast Yeti] #691792
05/08/10 08:13 AM
05/08/10 08:13 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Re: 540" short block [Re: firefighter3931] #691793
05/08/10 08:17 AM
05/08/10 08:17 AM
Dana Point, CA
Dana Point, CA
Hi Ron, I sure plan on being there with it. New tubs and body work are done, now I just need the motor and am ready to go. this time the car will be 250lbs less and 100+ hp more than the last time we were all there in Sept. a few yrs ago.
Re: 540" short block [Re: 69CHARGERMD] #691794
05/08/10 08:19 AM
05/08/10 08:19 AM
Dana Point, CA
Dana Point, CA
Hey Doug, maybe I will have enough power to do that kind of a wheele stand on motor alone this time?
Re: 540" short block [Re: Fast Yeti] #691795
05/08/10 08:57 AM
05/08/10 08:57 AM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Tom,Best of Luck with it! Yeah..540 sounds like a nice even number! Definately keep us posted on your build! Here's to your being able to "hang the hoops" without the nitrous! BTW...I've got an xtra rear bumper layin' around if ya need it in the future! RandyB
