Re: 540" short block [Re: Fast Yeti] #691796
05/08/10 09:04 AM
05/08/10 09:04 AM
NC
440Jim Offline
440Jim  Offline
NC
Jim I was running a 315/60 drag radial approx. 30" tall. I recently switched to 31x16.5 QTP that are 31" tall and will have some growth. I should trap at 7300 rpms in the 1/4. my 496" set up was a street/strip combo; pump gas and I used nitrous at the track so the 4.10 worked well. Now I am going to run all motor with a taller tire and the 4.56 seems to be best for wringing everything out of this combo.
Sounds like you have figured everything in. My 2-cents with over 500 CID is to start with the gears you have now (4.10), that might be just fine. After running it that way for awhile, you can always put more RPM to it later. The car might mph better than you think (145 vs 138?), and drive the RPM up accordingly. And all that torque will likely pull the 4.10/31" just fine (especially if you are running a torqueflite).
Re: 540" short block [Re: 440Jim] #691797
05/08/10 09:19 AM
05/08/10 09:19 AM
Dana Point, CA
Fast Yeti Offline OP
Dana Point, CA
Thanks Jim. Maybe I will try the 4.10 gears and see how the car runs. It would be great to not have to buy new gears.
Re: 540" short block [Re: Fast Yeti] #691798
05/08/10 10:21 AM
05/08/10 10:21 AM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Tom,not that I'm an expert on this,but I agree with Jim on the gearing! Why spend MORE money when You might not have to! Even though you're going with a taller tire,with ALL the torque that 540's going to make,I would say try what ya got first! Just my Randy
Re: 540" short block [Re: Labratt] #691799
05/08/10 12:05 PM
05/08/10 12:05 PM
IN
Dartman928 Offline
Dartman928  Offline
IN
Tom,
Sounds like a great combo
You'll be on the bumper
Re: 540" short block [Re: Dartman928] #691800
05/08/10 04:15 PM
05/08/10 04:15 PM
Dana Point, CA
Dana Point, CA
Thanks Randy and Rob. Hopefully I will have enough torque to get this big car moveing.
Re: 540" short block [Re: Fast Yeti] #691801
05/09/10 12:39 AM
05/09/10 12:39 AM
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Oh,You will!...I'm sure of that!!!
Re: 540" short block [Re: Fast Yeti] #691802
05/09/10 08:32 AM
05/09/10 08:32 AM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Hi Ron, I sure plan on being there with it. New tubs and body work are done, now I just need the motor and am ready to go. this time the car will be 250lbs less and 100+ hp more than the last time we were all there in Sept. a few yrs ago.
Cool....looking forward to seeing it run !
Ron
Re: 540" short block [Re: Fast Yeti] #691803
05/09/10 09:06 AM
05/09/10 09:06 AM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
I am going ro run all motor no N2o.
Looks like you will be having some fun.
and a truck to pull the car around.
Sounds like a plan. Tom, I hope I'll have mine together too and see you at Norwalk.
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: 540" short block [Re: Fast Yeti] #691804
05/09/10 09:17 AM
05/09/10 09:17 AM
ill
dennismopar73 Offline
ill
i just got thru putting 540 in 67 coronet
on alky @3800#
took 456 out put 410 in on 29 tall tire
i do think the motor will go 7 plus rpms
plus it do not think it needs to spin there
i figure the max hp is @620ish ?
the block is just a standard production
but does have girdle,crete but i dont think anyone should use a stock block in this combo
jmo
solid cam stx 22 with 1.6 rocker makes it like
720 lift
rpm heads ported max
i really think should found some 370 gears
put in the traps around 6300 i do not want to spin above 6800 rpms
