Collapsed Lifter? #690509
05/06/10 05:24 PM
05/06/10 05:24 PM
Nanaimo, B.C.
GwaiiEagle Offline OP
Mannix
Mannix
Nanaimo, B.C.
I swapped in the summit cam. Broke it in. Drove it around. Quite a bit of bottom end over the .484.
The next day the ticking started, followed soon after by a knocking or popping sound.
Is this a collapsed lifter?
Youtube vid attached.
Video of engine running.
Re: Collapsed Lifter? [Re: GwaiiEagle] #690510
05/06/10 05:37 PM
05/06/10 05:37 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
bummer, I'm thinking the worse.
Cut your oil filter apart.
Re: Collapsed Lifter? [Re: Challenger 1] #690511
05/06/10 05:50 PM
05/06/10 05:50 PM
Nanaimo, B.C.
Mannix
Mannix
Nanaimo, B.C.
Looking for some hunk of metal?
If you bring the revs up slowly there is a ticking but no popping. Want a vid of that?
Re: Collapsed Lifter? [Re: GwaiiEagle] #690512
05/06/10 06:11 PM
05/06/10 06:11 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Not good. If the popping is new, it might have wiped a lobe. A totally collapsed lifter would still give enough lift to not pop with the light throttle you gave it. Time to pull covers, I imagine. Maybe a pushrod fell out, if you're lucky.
Re: Collapsed Lifter? [Re: buildanother] #690513
05/06/10 06:23 PM
05/06/10 06:23 PM
New York City
groundpoint6 Offline
New York City
Sounds like a push rod popped out
Re: Collapsed Lifter? [Re: groundpoint6] #690514
05/06/10 06:24 PM
05/06/10 06:24 PM
Nanaimo, B.C.
Mannix
Mannix
Nanaimo, B.C.
I pulled the valve covers all the rockers seem tigh and intact except for one which feels very spongy.
Am going to pull intake.
With the intake out it is clear one of the lifters isn't like the others. You can press the pushrod down by hand and remove it.
Re: Collapsed Lifter? [Re: GwaiiEagle] #690515
05/06/10 06:50 PM
05/06/10 06:50 PM
New York City
New York City
Then that one spongy rocker sounds like a bad lifter
Re: Collapsed Lifter? [Re: groundpoint6] #690516
05/06/10 07:01 PM
05/06/10 07:01 PM
Nanaimo, B.C.
Mannix
Mannix
Nanaimo, B.C.
Here is vid of the lifter and me tugging on it. Lifter tugging
And of the lobe, too!
Re: Collapsed Lifter? [Re: GwaiiEagle] #690517
05/06/10 07:53 PM
05/06/10 07:53 PM
New York City
New York City
Why is that lifter sitting crooked in its boss
Re: Collapsed Lifter? [Re: groundpoint6] #690518
05/06/10 08:00 PM
05/06/10 08:00 PM
Nanaimo, B.C.
Mannix
Mannix
Nanaimo, B.C.
Why does this happen?
Re: Collapsed Lifter? [Re: GwaiiEagle] #690519
05/06/10 08:08 PM
05/06/10 08:08 PM
Cincinnati, Ohio
Cincinnati, Ohio
Sorry, cam and lifter failure. Why? Oil, too much spring pressure, wrong breakin procedure, bad cam core, poor material used for the lifters, wrong lash adjustment are just some that come to mind.
Need to pull the whole motor apart and inspect and clean everything expecially the oil gallerys.
Sorry again.
Re: Collapsed Lifter? [Re: Challenger 1] #690520
05/06/10 08:24 PM
05/06/10 08:24 PM
Nanaimo, B.C.
Mannix
Mannix
Nanaimo, B.C.
The bummer is the motor can come out and I have a another to put in but the other needs lifters for a solid. No way to get them here except by air for the start of the week.
I take the Ferry next Thursday to the drags.
Looks like I am taking the p/u.
Re: Collapsed Lifter? [Re: GwaiiEagle] #690521
05/06/10 08:42 PM
05/06/10 08:42 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Thats a heartbreak. I'm not going to build an engine with flat tappets again. They're all going to be roller - hydraulic or solid. This story is becoming too common for me. Once you buy a second cam and lifters, pull the engine apart and clean it I'm guessing the extra cost of the rollers might break even. Soryy dude thats too bad.
Re: Collapsed Lifter? [Re: groundpoint6] #690522
05/06/10 09:15 PM
05/06/10 09:15 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Good Question????
Somethings not right there and a crooked lifter bore, hard to imagine, would wipe a cam in a nanosecond
Re: Collapsed Lifter? [Re: TJP] #690523
05/06/10 10:12 PM
05/06/10 10:12 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Good Question????
Have you seen any lifters that were worn on that angle. I have seen them badly cupped, but not like the one he shows. I would check the diameter of the lifter bore and the diameter of the affected lifter. I think this is more than just a typical flattened cam.
I am assuming this wasn't a virgin block.
Re: Collapsed Lifter? [Re: Snoopy] #690524
05/07/10 04:44 AM
05/07/10 04:44 AM
Nanaimo, B.C.
Mannix
Mannix
Nanaimo, B.C.
No, I think it is the first build on a 77 block because it is only .020 over.
The valve train is non adjustable for this setup.
The .484 cam that was in there did not have this trouble.
The other lifters showed signs of wear, but this was the only one that looked like that.
Thanx for the help, though. The cam did make good power. I'll break it apart and see how the rest held up. Those metal shavings had to go somewhere.
Re: Collapsed Lifter? [Re: GwaiiEagle] #690525
05/07/10 10:24 AM
05/07/10 10:24 AM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
The next day the ticking started.....
I know this will seem like a silly question, but they were new lifters with the new cam right? The OP only mentioned a new cam. I assumed new lifters as well.
Re: Collapsed Lifter? [Re: Scott Carl] #690526
05/07/10 11:17 AM
05/07/10 11:17 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Like Snoopy said , that looks like the lifters aren't the right size for the bore. The lifters should be snug and have no side to side movement. It looks like both the lifters in that piture are cocked.
Re: Collapsed Lifter? [Re: stumpy] #690527
05/07/10 12:34 PM
05/07/10 12:34 PM
Cincinnati, Ohio
Cincinnati, Ohio
I think it's a optical illusion, no one would put lifters in loose. Now once the lifter started to wear, then I could see it getting outta wack.
The engine would not last 10 mins if the lifters were loose in there bores.
Re: Collapsed Lifter? [Re: Challenger 1] #690528
05/07/10 12:51 PM
05/07/10 12:51 PM
chicagoland,usa
chicagoland,usa
And they would never hold pressure, and would be ticking up a storm from the start.
