Page 3 of 6 1 2 3 4 5 6
Re: Ready for interior and final assy. [Re: Dartman440] #690081
12/07/10 02:35 PM
12/07/10 02:35 PM
Southern Michigan
Dartman440 Offline OP
Southern Michigan
Ready for the rest.
Re: Ready for interior and final assy. [Re: Dartman440] #690082
12/07/10 02:36 PM
12/07/10 02:36 PM
Southern Michigan
Southern Michigan
Left Side
Re: Interior [Re: Dartman440] #690083
12/07/10 02:50 PM
12/07/10 02:50 PM
Southern Michigan
Southern Michigan
The interior was done in Italian Leather by Top Notch Interiors of Livonia, Michigan. Ramone Oudeh. He does interiors for Jay Leno, Porsche and Rolls Royce, Concept cars etc. He does exec. work reasonable. We took stock Recaros and stripped them down and modified the frames and sculpted them to a cooler look.I had the guy's name I built the car for stitched in Sublime on the front seat covers and we made a custom dash cover with his name on it also. That was my Idea.
Re: dash pad [Re: Dartman440] #690084
12/07/10 02:52 PM
12/07/10 02:52 PM
Southern Michigan
Southern Michigan
Here is the dash pad looks better than the original.
Re: dash pad [Re: Dartman440] #690085
12/07/10 02:54 PM
12/07/10 02:54 PM
Southern Michigan
Southern Michigan
Better shot of the pad
Re: Back Seat [Re: Dartman440] #690086
12/07/10 02:57 PM
12/07/10 02:57 PM
Southern Michigan
Southern Michigan
Back seat was done in Leather also.
Re: Wheels on the car [Re: Dartman440] #690087
12/07/10 03:04 PM
12/07/10 03:04 PM
Southern Michigan
Southern Michigan
Here are the fronts. I kind of like these a retro 5 spoke. Kind of classic but it is not. Like the whole theme of the car.
Re: Wheels on the car [Re: Dartman440] #690088
12/07/10 03:07 PM
12/07/10 03:07 PM
Southern Michigan
Southern Michigan
The rear tires. I was also putting the car on the scales to check out the front and rear weight ratios.
Re: Wheels on the car [Re: Dartman440] #690089
12/08/10 10:39 AM
12/08/10 10:39 AM
Southern Michigan
Southern Michigan
Weighing In. Car has a perfect front to rear ratio.
Re: Wheels on the car [Re: Dartman440] #690090
12/08/10 10:44 AM
12/08/10 10:44 AM
Southern Michigan
Southern Michigan
The front weight was 1846 Lbs. The rear was 1745 Lbs.
Re: Trans is in [Re: Dartman440] #690091
12/08/10 10:46 AM
12/08/10 10:46 AM
Southern Michigan
Southern Michigan
The keisler set up. This was the brute trans for over 750 H.P.
Re: Front Susp [Re: Dartman440] #690092
12/08/10 10:53 AM
12/08/10 10:53 AM
Southern Michigan
Southern Michigan
Here is a good shot of the front. This whole set up was very very tight dropping the body on the K member.A lot of work went into making the oil pan fit. All the stainless braided lines. This has a Hydro Boost power brake system.Lots of tedius hours of custom fitting everything. But it all came together real nice. This car was made to be very practical with hardly any maintainence and beat the heck out of it.
Re: Interior [Re: Dartman440] #690093
12/08/10 10:55 AM
12/08/10 10:55 AM
Southern Michigan
Southern Michigan
Starting on the interior. Hush Mat was used,
Re: Interior [Re: Dartman440] #690094
12/08/10 10:56 AM
12/08/10 10:56 AM
Southern Michigan
Southern Michigan
The rear
Re: Interior [Re: Dartman440] #690095
12/08/10 11:00 AM
12/08/10 11:00 AM
Southern Michigan
Southern Michigan
The Heater box was restored new core and Kit From Moparts Member James (71 T/A). I also bought the firewall and body gasket kit from him. The heater box still had the part number stenciled on it from the factory.
Re: Interior [Re: Dartman440] #690096
12/08/10 11:02 AM
12/08/10 11:02 AM
Southern Michigan
Southern Michigan
Here is a before and after shot of the dash
Re: Interior [Re: Dartman440] #690097
12/08/10 11:05 AM
12/08/10 11:05 AM
Southern Michigan
Southern Michigan
After
Re: Interior [Re: Dartman440] #690098
12/08/10 11:16 AM
12/08/10 11:16 AM
Southern Michigan
Southern Michigan
Carpet is in. I put power windows in front and rear and wired it all looked factory. The Kit I bought from XV Motorsports. Carpet and dash are in.Headliner is in. The carbon fiber dash applique I bought from (71 T/A) also. That gave it the new look with the original gauges, Thanks James it was a good touch.
Re: Interior [Re: Dartman440] #690099
12/08/10 11:17 AM
12/08/10 11:17 AM
Southern Michigan
Southern Michigan
Seats are in.
Re: Interior [Re: Dartman440] #690100
12/08/10 11:18 AM
12/08/10 11:18 AM
Southern Michigan
Southern Michigan
Front Seat.
