Zinc in Marvel Mystry Oil .. #688684
05/04/10 09:40 PM
05/04/10 09:40 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
With all the problems with the oil and wiping out cams because the manufacturers removed the zinc from the oil for today's cars,I know many years ago I read an article about Marvel Mystry Oil..And the people from Marvel were asked what is the mystry additive.and they wouldnt say..So an independant lab did an analisis of it and I know I read that the mystry stuff was zinc..I'm 90% sure of it..but it was a real long time ago..Can anybody verify that ???I would be a great and inexpensive additive for the cam- zinc problem
Re: Zinc in Marvel Mystry Oil .. [Re: dynamite] #688685
05/05/10 01:23 AM
05/05/10 01:23 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I thought it was mineral spirits with some other stuff thrown in. Pretty good for blowing out carbon or freeing stuck pistons in a rusty old core motor.
Re: Zinc in Marvel Mystry Oil .. [Re: bobby66] #688686
05/05/10 03:45 AM
05/05/10 03:45 AM
Tacoma, Wa.
danbs23 Offline
danbs23  Offline
Tacoma, Wa.
I don't know about Marvel Mystery Oil but I understand most motorcycle oils have zink in it.
Re: Zinc in Marvel Mystry Oil .. [Re: danbs23] #688687
05/05/10 06:27 AM
05/05/10 06:27 AM
michigan
sturmenater Offline
sturmenater  Offline
michigan
The MSD sheet for marvel mystery oil keeps it a mystery.
Says mineral spirits and other petroleum lubricats along with other non lethal indgredents I swear the secret is mint oil. Thats my educated quess
Re: Zinc in Marvel Mystry Oil .. [Re: dynamite] #688688
05/05/10 11:21 AM
05/05/10 11:21 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The "Mystery" to me has always been what to do with it.
They call it a "top end" lubricant. Top end of what ???
How is it used ? It has no viscosity rating so you can't just fill an oil pan with 5 quarts!
We always used it in the burrette to cc heads and cylinders 'cause its thin and the color made it easy to read.
Re: Zinc in Marvel Mystry Oil .. [Re: Stanton] #688689
05/05/10 12:11 PM
05/05/10 12:11 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Used as an oil additive in conservative amounts, it can quiet sticky, gummed up lifters and similar old-gunky-engineness.
Color me dubious when it comes to zinc content.
Personally, I use it as air tool oil.
Down to just a blue car now.
Re: Zinc in Marvel Mystry Oil .. [Re: 68HemiB] #688690
05/05/10 03:44 PM
05/05/10 03:44 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Silenced the lifters in my 318
The stuff rocks, my dad used it all the time.
Re: Zinc in Marvel Mystry Oil .. [Re: dynamite] #688691
05/05/10 03:48 PM
05/05/10 03:48 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Before there was all these bogus tigerwizz products, there was Mystery Oil. The 'gandaddy' to all that stuff. See the part about 'mineral spirits'? You should figure it out from there. The first cheap trick you did when the engine ran rough, was pour a qt. of Mystery Oil down the carburetor while the engine is running at a high RPM. They knew they were cleaning out something. Just what they cleaned out didn't matter. It fixed it. Combining mineral spirits with oil was "voo-doo" science back then.
Yup. We had a lot of voo-doo science back then...
Re: Zinc in Marvel Mystry Oil .. [Re: Commando1] #688692
05/05/10 05:20 PM
05/05/10 05:20 PM
scratchnfotraction Offline
around here its VooDoo snake oil
Re: Zinc in Marvel Mystry Oil .. [Re: scratchnfotraction] #688693
05/05/10 05:37 PM
05/05/10 05:37 PM
Seymour,IN.
HoosierGTX Offline
HoosierGTX  Offline
Seymour,IN.
We have used Marvel oil many times on farm tractors that have the engines stuck from sitting,it's still a useful product to have on the shelf!
Re: Zinc in Marvel Mystry Oil .. [Re: 68HemiB] #688694
05/05/10 05:38 PM
05/05/10 05:38 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
I use it in my air tools. I love the wintergreen aroma
Re: Zinc in Marvel Mystry Oil .. [Re: Scott Carl] #688695
05/05/10 06:42 PM
05/05/10 06:42 PM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
Local AutoZone doesn't carry it, so I used "Seafoam", same kinda stuff, great results in freeing up stuck lifters.
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Zinc in Marvel Mystry Oil .. [Re: dynamite] #688696
05/12/10 07:49 AM
05/12/10 07:49 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
This is copied from another thread.
We analyzed and tested both of these additives at Exxon.
Marvel Mystery oil is 30% varsol (charcoal lighter fluid) and 70% 30wt base oil some red dye and wintergreen fragrance. It is from the late 1920s.
Avblend is very light weight paraffinic base oil (sewing machine oil)with 1% ether and blue dye. It is from the late 1950s. If it is absorbed by the metal, why doesn't it leak out of the can?
These are solvent type products. Some people find them beneficial for sticky valves or some sludge dispersal. If you are depending on them for either of these reasons, you have bigger problems.
Both evaporate within hours in an engine. Neither one provides any corrosion protection or anti-wear benefit. Neither one will harm anything in the recommended concentration.
Regards,
Ed
Edward Kollin
Techncal Director
Aircraft Specialties Lubricants
www.aslcamguard.com
Re: Zinc in Marvel Mystry Oil .. [Re: 360view] #688697
05/12/10 08:09 AM
05/12/10 08:09 AM
Commando1 Offline
Commando1  Offline
Found on line:
Q: What is the difference between Varsol® and regular Paint Thinner?
A: Regular Paint Thinner is a "generic" brand of thinner while Varsol® carries a guarantee of purity. As a result, Paint Thinner is usually less expensive than Varsol® but can be used for many of the same applications.
So, it's safe to say that Mystery oil is one part thinner to 2.3 parts oil.
Re: Zinc in Marvel Mystry Oil .. [Re: 360view] #688698
05/12/10 03:17 PM
05/12/10 03:17 PM
S.E. Conn
S.E. Conn
Regards,
Ed
Edward Kollin
Techncal Director
www.aslcamguard.com
How come my oil level hasn't dropped then?
2005 300C Hemi
Re: Zinc in Marvel Mystry Oil .. [Re: Hoof Hearted] #688699
05/12/10 06:27 PM
05/12/10 06:27 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
70% Light Aromatic Oil (Pale Oil)
- It is a Naphthenic Oil, so while it oxidizes faster than a Paraffinic oil, it does clean and dissolve sludge and carbon well and cleans up after itself from any oxidation. serves as base oil as well. [Naphthenic oils have more solvency and are more polar (they are attracted to metal more), but oxidize faster.
29% Mineral Spirits
- Cleans Varnish very well. General cleaner. Also acts as an antioxidant.
38 parts per million (ppm) Boron
- AW/EP agent, friction reducer, antioxidant
900 ppm Phosporous
- AW/EP agent
1/2% 1, 2 ortho-Dichlorobenzene
- EP agent as it interacts with Iron to form an Iron chloride barrier under any ZDDP or other AW additives. Also very good cleaner/solvent, and friction reducer
1/4% 1, 4 para-Dichlorobenzene
Oil of wintergreen - for the scent
- Not just for the cent, is also a cleaner. may aid lubricity.
Red Dye - for the color
- well this one just colors the stuff
http://www.bobistheoilguy.com/forums/ubb...;gonew=1#UNREAD
It's Swifty! Swifty, you toad sucker!
Re: Zinc in Marvel Mystry Oil .. [Re: zrxkawboy] #688700
05/12/10 09:44 PM
05/12/10 09:44 PM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
we use it to shine up the interior of Wilbert burial vaults prior to the funeral service.
Re: Zinc in Marvel Mystry Oil .. [Re: cornucopia] #688701
05/12/10 11:07 PM
05/12/10 11:07 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
What is a "Wilbert" burial vault?
Re: Zinc in Marvel Mystry Oil .. [Re: Ramrod39] #688702
05/13/10 09:23 AM
05/13/10 09:23 AM
Commando1 Offline
Commando1  Offline
Re: Zinc in Marvel Mystry Oil .. [Re: Commando1] #688703
05/14/10 12:31 AM
05/14/10 12:31 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Oh. It's a T-shirt. Thanks!
