Who has used VHT high temp paint on headers #687554
05/03/10 07:04 PM
05/03/10 07:04 PM
MD
75dusted Offline OP
75dusted  Offline OP
MD
Who here has used VHT high temp paint on headers? How long has the paint lasted and does it bubble , or flake off
Re: Who has used VHT high temp paint on headers [Re: 75dusted] #687555
05/03/10 07:10 PM
05/03/10 07:10 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I used it. Had an old set of headers blasted and then used their primer and paint. It was on the 72 that only sees track time but it held up ok for a while. Then it started to show rust through the paint. Pretty much like any other paint I've tried.
I would think el cheepo BBQ paint would work as good.
That said, member PROSPORT has his headers painted W/ an Eastwood Co high heat silver and he's been real happy with how they've held up.
Re: Who has used VHT high temp paint on headers [Re: 75dusted] #687556
05/03/10 09:31 PM
05/03/10 09:31 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Haven't used that, but have used rustoleum BBQ paint (silver), it's cheap, available everywhere, and plain works!
Re: Who has used VHT high temp paint on headers [Re: 75dusted] #687557
05/03/10 09:51 PM
05/03/10 09:51 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
burned off in 200 miles.waste of time.
Re: Who has used VHT high temp paint on headers [Re: 75dusted] #687558
05/03/10 10:08 PM
05/03/10 10:08 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Needs sandblasting to prep. Goes on like water. Scratches easily till its cured. Doesn't last.
Re: Who has used VHT high temp paint on headers [Re: Stanton] #687559
05/03/10 10:19 PM
05/03/10 10:19 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Mine started rusting through the vht paint within a month of use. Will try something else next time.
Re: Who has used VHT high temp paint on headers [Re: Stanton] #687560
05/03/10 10:31 PM
05/03/10 10:31 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
I agree for the most part. The headers on my wife's Barracuda looked good for 3 years using VHT ceramic black paint. With that said, it's just a fair weather cruiser. If we drove it every day, the paint would have gone south much faster.
I had the headers ceramic coated black by a local company over the winter. We'll see how they last this time around.
Re: Who has used VHT high temp paint on headers [Re: Blues_Cuda] #687561
05/03/10 11:18 PM
05/03/10 11:18 PM
Santa Barbara, CA
HitIt Offline
HitIt  Offline
Santa Barbara, CA
Pretty much crap. It came right off in a blaze of smoking glory. Don't waste your time.
Re: Who has used VHT high temp paint on headers [Re: HitIt] #687562
05/03/10 11:32 PM
05/03/10 11:32 PM
southern California
1970sixpak Offline
1970sixpak  Offline
southern California
I have had good luck with vht so far. My car only has only about 100 miles on it. I guess time will tell.
Re: Who has used VHT high temp paint on headers [Re: 75dusted] #687563
05/04/10 12:17 AM
05/04/10 12:17 AM
New Jersey
Alan Offline
Alan  Offline
New Jersey
For success, one must:
1) Sandblast - and wear rubber gloves so your skin oil does not contaminate the clean metal
2) Wipe down w/ acetone - to get and grease or oil out if there...
3)Spray two coats VHT - more will cause blistering.
4) Ona cookie sheet, "bake" your painted headers up to 450 degrees temp in you kitchen oven ( hint: make sure wife is gone for the day).
5) bolt up and enjoy.
- Alan Moderator Emeritus ~ Soon to unveil the world's only '69 Road Runner 440 R/T... "A fantasy car that never existed, but could have."
Re: Who has used VHT high temp paint on headers [Re: Alan] #687564
05/04/10 12:23 AM
05/04/10 12:23 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I guess if you have an oven big enough for headers, you can go into business baking Pizzas!
I have had crappy luck with all the spray on stuff. The only proven remedies that will stand up to the rigors of full throttle runs and bumper to bumper traffic include Ceramic coating and Ceramic coating. Oh wait ... also Ceramic coating.
Re: Who has used VHT high temp paint on headers [Re: Kern Dog] #687565
05/04/10 09:03 AM
05/04/10 09:03 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Ya, like who has an oven that big ?!?!?!?
Re: Who has used VHT high temp paint on headers [Re: Stanton] #687566
05/04/10 11:10 AM
05/04/10 11:10 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
He must have small ones!
Re: Who has used VHT high temp paint on headers [Re: RodStRace] #687567
05/04/10 12:04 PM
05/04/10 12:04 PM
Santa Barbara, CA
HitIt Offline
HitIt  Offline
Santa Barbara, CA
You don't have to use an oven. On the can they have a procedure to cure it on the car. Something like idle it for ten minutes, let it cool completely, repeat, run for 20 minutes etc. Oh and the final steps: watch it all fall off and the rust appear.
Re: Who has used VHT high temp paint on headers [Re: HitIt] #687568
05/04/10 01:02 PM
05/04/10 01:02 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Instead of VHT, I used Eastwood's High Temperature Exhaust paint. I first glass-bead blasted my manifold, then (wearing rubber gloves) washed it with hot soapy water, rinsed and blew it dry with compressed air. I applied a liberal coating of Eastwood's PRE paint prep, then sprayed a couple coats of the High Temp paint on. I've put over 1,000 miles on it since January 2009, and haven't noticed any flaking or rusting.
Re: Who has used VHT high temp paint on headers [Re: Fab64] #687569
05/04/10 03:35 PM
05/04/10 03:35 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I used it on manifolds and found it worked well.
Headers...not a chance. They are a totally different ball game. Even powder coating will come off if you have a problem with timing etc..
As mentioned, don't waste your time
Re: Who has used VHT high temp paint on headers [Re: dave571] #687570
05/04/10 03:57 PM
05/04/10 03:57 PM
Howell, Michigan
Hemidavey Offline
Hemidavey  Offline
Howell, Michigan
I've used VHT on headers it lasted 2 years then started going bad slowly. Acetone wash and sand blast prep is a must. If you touch them with your bare hands before or after paint you will see it soon! I gave up on ceramic coatings, my new Jet Hot headers rusted and so did another fellows, not sure where he went. Mine are pealing badly on my Dart. Jet Hot did em twice! The only thing that I find that works every time is stainless steel. Its only too expensive if your selling the car. I've had my Cuda for 27 years, never using mild steel again. Ad up the value of your time , blasting, paint, prep year after year?
Re: Who has used VHT high temp paint on headers [Re: 75dusted] #687571
05/04/10 04:29 PM
05/04/10 04:29 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
I for one have had no luck with any type of paint on headers
Re: Who has used VHT high temp paint on headers [Re: GTXKen] #687572
05/06/10 09:09 PM
05/06/10 09:09 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Maybe VHT has gone south like a lot of good products?? DUNNO???
I've used it for years and never had an issue. But it's been awhile since I've used it on a daily driver. Limited use within the last 3 or so years on customers cars and it's held up fine. I know this from when they come in for periodic maintenance. Powder /Ceramic coatings etc all seem to fail rather quickly. Especially in the areas that don't get adequately coated IE: between the tubes etc.
Re: Who has used VHT high temp paint on headers [Re: TJP] #687573
05/06/10 09:26 PM
05/06/10 09:26 PM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
just sandblast headers and use stove polish, the stuff you brush on then rub in. works like a charm.
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
