MSD Digital 6 ???? #686769
05/02/10 07:17 PM
05/02/10 07:17 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Anny one on here have anny problems with thare MSD Digital 6 box?
My car is missing and I can't seem to track it down.
I have HVC coil, Pro billet dizzy, Taylor wires, fresh NGK 10s, all the power wires and dizzy wires look ok.
Alternator is working good, its not low on voltage.
Re: MSD Digital 6 ???? [Re: RockChip] #686770
05/02/10 07:28 PM
05/02/10 07:28 PM
Stockholm, Sweden
TomsCharger70 Offline
Stockholm, Sweden
To me it seems like the MSD ignition boxes are "programed" to suddenly stop working after X amount of time.. I know several who has had major problems when running the Digital 6 box...
My Digital 6 stoped working and I couldnt find any reason why.. It will give out a spark when under 3000Rpm, above that the engine just doesnt run right, changed it out for my trusty old 7AL box and everything is fine again...
/Tom
Re: MSD Digital 6 ???? [Re: TomsCharger70] #686771
05/02/10 07:52 PM
05/02/10 07:52 PM
Q
Quicktree Offline
Quicktree  Offline
Q
are your big red and black wires going directly to the battery?
Re: MSD Digital 6 ???? [Re: Quicktree] #686772
05/02/10 08:49 PM
05/02/10 08:49 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Yes thay are to the battery.
Re: MSD Digital 6 ???? [Re: RockChip] #686773
05/02/10 09:02 PM
05/02/10 09:02 PM
Q
Quicktree Offline
Quicktree  Offline
Q
there is so many things that could cause a miss it's hard to guess. could be something other than your ignition box. just have to start a process of elimination. simple things first.
Re: MSD Digital 6 ???? [Re: Quicktree] #686774
05/02/10 09:21 PM
05/02/10 09:21 PM
Cornwall, N.Y.
B3Cuda Offline
B3Cuda  Offline
Cornwall, N.Y.
Lol I switch them around red is negative & black is hot. In all actuality the negative is grounded on the frame as a common ground not back to the battery as for the red it gets power from the the wire going to the switch box. I want to eliminate the easy stuff first but I was checking to see if I was doing something wrong from the beginning. From what I see it seems to be wired correctly. My car is wired very simple with a painless switch panel and not all cut up.
Re: MSD Digital 6 ???? [Re: B3Cuda] #686775
05/02/10 09:55 PM
05/02/10 09:55 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
mine used to miss at 63-6400rpm. mounting the box under the dash was the biggest improvement. it was under the hood previously. run the large positive lead directly to battery and large ground to chassis using no more the 2ft of wire for ground, the shorter the better and you may need the shielded pickup lead also. this should fix your problem.
Re: MSD Digital 6 ???? [Re: mopar dave] #686776
05/02/10 10:31 PM
05/02/10 10:31 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Yes mine is mounted in the glove box area.
Ive been hearing the digital-6 is prone to problems, and that the digital-7 is a better choice?
Re: MSD Digital 6 ???? [Re: RockChip] #686777
05/02/10 11:05 PM
05/02/10 11:05 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Sheilded pickup or try switching the pickup wires...
Re: MSD Digital 6 ???? [Re: mopar dave] #686778
05/02/10 11:27 PM
05/02/10 11:27 PM
Cornwall, N.Y.
B3Cuda Offline
B3Cuda  Offline
Cornwall, N.Y.
Mine is mounted inside the car on a pan on the floor, & the pickup lead is shielded as well, so I guess I will try running a wire straight to the battery. Ground wire is maybe about a foot long.
Re: MSD Digital 6 ???? [Re: B3Cuda] #686779
05/02/10 11:35 PM
05/02/10 11:35 PM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
I run digital 6 also and mine was doing the same thing at 6500, Switch to the shielded pick-up harness and ran it by itself, not by any other power wires and problem was fixed...Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
