Re: very low oil pressure on 511
[Re: Glen440]
#685682
05/03/10 08:27 PM
05/03/10 08:27 PM
Posts: 16,923 NC
440Jim
NC
it has a solid roller cam with .760, .716 lift with 1.7 T&D shaft rockers. Maybe the lifters are uncovering the oil feed?
It could be the lifters/bore, but I don't think so. That is not a lot of lobe lift:
.760"/1.7 = 0.447"
So a normal 1.5 rocker arm (stock head) would only be 0.670" valve lift with that cam. And tons of guys have run that in stock blocks, rocker ratio, etc. And on top of that, the roller lifters from IMM should not be a problem at that lobe lift either.
[Re: moparniac]
#685684
05/03/10 08:36 PM
05/03/10 08:36 PM
Posts: 1,397 Toronto Ontario, Can
Glen440
I went by their instructions, took 2 tries to get the right pushrods as measuring my checking pushrod and what showed up were .050 different which is around a full turn and were too long. I have 8.950 in the intakes and 8.900 in the exhaust. Only had to send 8 back, plus took 3 tries to get 8.950's as they kept sending some 8.050 in the 8.950 package. offset rollers in the intakes as well.
87 dakota 6.1 hemi
[Re: Glen440]
#685685
05/03/10 08:38 PM
05/03/10 08:38 PM
Posts: 6,295 U.S.
moparniac
U.S.
With the offset lifters mine were 2 different lengths also...
Mopar Performance
[Re: MR_P_BODY]
#685687
05/03/10 09:00 PM
05/03/10 09:00 PM
Glen440
The bearing clearances are good. I had the machine shop that did the bore and hone measure everything.
It looks like there is not much flow. I have the valvetrain out so I was pulling lifters up while priming to see what was going on. It does not make enough pressure to get any oil out the top of the lifter. You pull a lifter right out and its not a constant flow of oil out the big hole.
87 dakota 6.1 hemi
[Re: Glen440]
#685688
05/03/10 09:06 PM
05/03/10 09:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Are you SURE all the plugs are in the oil galleys, a stock pump should flow enough to give you decent pressure.... I'm just asking
[Re: Glen440]
#685689
05/03/10 09:08 PM
05/03/10 09:08 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Glen,
Is there any chance you are sucking the inside wall ( rubber) of the braided suction line in? IE: A collapsed oil line? Check that suction line. No way something got into the pick up ? IE rag, towel etc? Just thinking out loud. Seems like a suction side problem.
RIP Monte Smith
[Re: CompWedgeEngines]
#685690
05/03/10 09:17 PM
05/03/10 09:17 PM
Glen440
Anything is possible, I put the pan on last wed and left the engine upside down so a rag is unlikely. I had it in the parts washer and cleaned the pickup and blew it out with air. I can make a new suction line, maybe it got hurt putting it in the car.
Pbody, my very first thought was the 2 plugs in the front so I pulled the front apart and looked and they are in there, the back ones must be or I would have oil everywhere. I plugged the internal pickup at the pump and inside by the crank. Is there anymore?
Maybe the pump cover has something wrong with it?
87 dakota 6.1 hemi
[Re: Glen440]
#685691
05/09/10 11:39 AM
05/09/10 11:39 AM
Glen440
I don't exactly know what was wrong with the oiling system. I put a different relief valve in and it got more oil pressure. I put a new high volume pump on it because I was gonna take the pump off anyway. I decided to run the suction line differently to elimate one 90 fitting and the line is almost completely straight now. Maybe the bend in the line was an issue? I did not take the pan off. I can get 60 psi priming it now and cold it has 75 at idle. I had it running for about 10 min yesterday and forgot what it had hot, maybe 25 at idle. I also had the oil heater on for a couple hours so the oil was warm before it started. Its real cold here right now, weather is strange. Some snow. I'm just about to put the K frame back in, had to do some hacking on it to fit the oil line. At least its fixed.
87 dakota 6.1 hemi
[Re: Glen440]
#685692
05/09/10 11:46 AM
05/09/10 11:46 AM
Posts: 16,923 NC
440Jim
NC
At least its fixed
I agree with that. Sounds like the pump and relief may have both been an issue. I don't know about the lines. Quote:
I have a static pickup in the pan with #12 line feeding the pump. This pump and pan setup worked when last ran.
