Page 2 of 7 1 2 3 4 5 6 7
Re: Running hot with 440 source housing and pump [Re: moparts] #685463
05/01/10 08:45 PM
05/01/10 08:45 PM
The pump is made by Cat and is sold by many different people.
I have a NIB cat pump going onto a mild 451
Re: Running hot with 440 source housing and pump [Re: fourgearsavoy] #685464
05/01/10 09:00 PM
05/01/10 09:00 PM
dark side of the moon
Dougsmopars Offline OP
in stop and go traffic it pegged the gauge. Starts to ping at light throttle, it's hot. As mentioned by others engine compartment heat is high. Heat radiating off motor is much higher then before. Plenty of complaints on those 440 source houseings and pumps. I'll try changing the pump. It's way cheaper then a motor.
Re: Running hot with 440 source housing and pump [Re: moparts] #685465
05/01/10 09:02 PM
05/01/10 09:02 PM
The houseing passage is much smaller then hole in block. I can't even get a finger in the port on houseing
Re: Running hot with 440 source housing and pump [Re: Challenger 1] #685466
05/01/10 09:03 PM
05/01/10 09:03 PM
Same fan that was on it before swapping the houseing and pump. Works fine.
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685467
05/01/10 09:07 PM
05/01/10 09:07 PM
That IS a prob
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685468
05/01/10 09:10 PM
05/01/10 09:10 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
They do go bad, expecially if there stored flat and put back on the car.
It's what keeps the engine cool(fan clutch) during stop and go. You should be able to hear the fan when it's working during hi temps.
I've seen em go bad with more than one car over the years.
Re: Running hot with 440 source housing and pump [Re: Challenger 1] #685469
05/01/10 09:14 PM
05/01/10 09:14 PM
Well it was only off the car for 3 days while i changed the cam and houseing. I doubt it went bad in those 3 days. Yes you can hear it working. Car ran rock steady at 180 to 190 all day in 90 degree heat. Now with that houseing it runs very hot and it's only 75 degrees out.
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685470
05/01/10 09:18 PM
05/01/10 09:18 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Sounds like an air pocket.
Re: Running hot with 440 source housing and pump [Re: RapidRobert] #685471
05/01/10 09:25 PM
05/01/10 09:25 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Ok, so you changed the water pump, water pump housing, and the CAM...and you think the overheating is from the water pump?
I'd look at the cam swap before the water pump. with a cam change, your carb will need re-tuned, and your timing will need re-tuned. you could be lean, your timing could be way off...and that could be a HUGE reason for running hot.
I'd suspect that before the water pump.
**Photobucket sucks**
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685472
05/01/10 09:30 PM
05/01/10 09:30 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
ok, that might be a problem...can you open it up at all to be at least as big as the holes in the block?
my housing from 440 source works fine...I had to replace the pump though, but only because my custom serp set-up has the pump spinning backards, so I needed a pump with straight vanes that would work when spun backwards.
Re: Running hot with 440 source housing and pump [Re: ireland383] #685473
05/01/10 09:31 PM
05/01/10 09:31 PM
Fredericktown, PA 15333
maundmotorworks Offline
Stealth poster
Stealth poster
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
Re: Running hot with 440 source housing and pump [Re: 70Cuda383] #685474
05/01/10 09:32 PM
05/01/10 09:32 PM
And you should read the whole post before speaking. Carb is set timing is set. Carb is actually a bit rich not lean.
Re: Running hot with 440 source housing and pump [Re: 70Cuda383] #685475
05/01/10 09:33 PM
05/01/10 09:33 PM
The Dalles, OR.
Dusted_Ya Offline
Dusted_Ya  Offline
The Dalles, OR.
First off what cam are you running. Second what is your initial timing? Third and most importantly did you use a NEW valley pan? I did a cam change on a motor with less than 500 miles on it and reused the old the valley pan. after changing everything out 2-3 times I finally pulled the intake and sure enough it was sucking air and oil out of the valley area. Funny thing was it didn't run like it had a vacuum leak and the plugs never showed oil consumption but after I changed the pan it stopped overheating.
Re: Running hot with 440 source housing and pump [Re: ireland383] #685476
05/01/10 09:34 PM
05/01/10 09:34 PM
NH
Fastback67 Offline
Fastback67  Offline
NH
Change the pump and change the thermostat to a 180. The housing will be fine... Yes it has a smaller port on one side, but so do many of the other (flow balanced) aftermarket housings.... 440 Source just happens to be the smallest.
Bottom line... I ran a whole series of controlled bench tests a while back using various housings and pumps...and the 440 Source housing with a stock pump flowed just as well as the stock Mopar housing with the same pump. The 440 Source pump however, was the dog of the bunch, especially at low rpm's.
Re: Running hot with 440 source housing and pump [Re: Dusted_Ya] #685477
05/01/10 09:38 PM
05/01/10 09:38 PM
Lunati 513/533 Initial is happest at 20 degree's yes new valley pan i never reuse a gasket. I think the problem is the pump. easy change to find out.
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685478
05/02/10 12:37 PM
05/02/10 12:37 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
ALSO! Before bolting the new pump on, determine the impeller-to-housing clearance. There have been reports of interference and/or excessive clearance with some combinations.
I would think the most effective is for the impeller to be as close as possible to the housing, w/o interference.
As stated by another poster, the design of the 440source impeller does not look like it would flow well.
Report back with your results!
Re: Running hot with 440 source housing and pump [Re: Pacnorthcuda] #685479
05/02/10 01:26 PM
05/02/10 01:26 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
IMO, get a Milodon HV pump and be done with it.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Running hot with 440 source housing and pump [Re: Von] #685480
05/02/10 03:17 PM
05/02/10 03:17 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
FWIW I just got back from a nice romp in 95 degree weather with my cat housing and a Napa replacement water pump and car never went above 175 degrees.
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685481
05/02/10 04:46 PM
05/02/10 04:46 PM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
I had the same problem with their stuff went with another pump and housing, 44O Housings are JUNK
Re: Running hot with 440 source housing and pump [Re: TOMRR] #685482
05/04/10 09:28 PM
05/04/10 09:28 PM
NJ
440challenger Offline
NJ
Did the pump fix it?
Im having a problem with my dads 440. We are using a 26" champion alum rad, new thermal clutch on 7 blade MP fan. Flushed the block. goes to 215 on the high way. Gets so hot that the fuel boils and car cuts in and out.
I have a 440 source pump and housing on it...
Doesnt puke coolant but just runs super hot!
We took the clutch fan off today and put an HHR elec fan and shroud on and its still 200 degrees on a cool 70 degree night
