66 A Body Pitman Arm??? #681910
04/27/10 05:00 PM
04/27/10 05:00 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Does anyone know where I can get a pitman arm for a 66 Dart (manual steering)?
Re: 66 A Body Pitman Arm??? [Re: mopowers] #681911
04/27/10 08:55 PM
04/27/10 08:55 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Not 100% sure but IIRC the arm you need was used on all A-bodies up to '72 and is the same for manual and power steering.
Re: 66 A Body Pitman Arm??? [Re: 446acuda] #681912
04/27/10 10:59 PM
04/27/10 10:59 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
This page shows I need part # K7020, while 67-72 A bodies used K7074 Does anyone still carry pitman arms for these early A's?
http://www.bigblockdart.com/techpages/moognumbers.shtml
Re: 66 A Body Pitman Arm??? [Re: mopowers] #681913
04/28/10 12:37 AM
04/28/10 12:37 AM
Yes 63-66 A is unique. Your parts house didn't have one? Mine did but it's been a year or 2
Re: 66 A Body Pitman Arm??? [Re: RapidRobert] #681914
04/28/10 12:42 AM
04/28/10 12:42 AM
North Las Vegas
chewy Offline
chewy  Offline
North Las Vegas
5 or so years ago when I rebuilt the front-end, I got mine from PST. I think it was about $100.
I had tried junkyard diving a couple times and found what I thought were solid ones, and they just loosened up after a few miles.
Ended up with the full rebuild kit (Poly Graphite) and bought the pitmann arm separate (Its an extra cost).
http://www.p-s-t.com/c-133-suspension.aspx
Re: 66 A Body Pitman Arm??? [Re: chewy] #681915
04/28/10 12:51 AM
04/28/10 12:51 AM
North Las Vegas
chewy Offline
chewy  Offline
North Las Vegas
Re: 66 A Body Pitman Arm??? [Re: chewy] #681916
04/28/10 10:43 AM
04/28/10 10:43 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks guys.
Lastly, where's a good place to get a idler arm also (k414)?
Re: 66 A Body Pitman Arm??? [Re: mopowers] #681917
04/28/10 03:28 PM
04/28/10 03:28 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
bump???
Re: 66 A Body Pitman Arm??? [Re: mopowers] #681918
04/29/10 12:33 AM
04/29/10 12:33 AM
North Las Vegas
chewy Offline
chewy  Offline
North Las Vegas
One on the same page as above for $68.
Full front-end kits are there also.
I like the firm fill of the poly graphite, but after about 3 years, it started squeeking when it was cold. Not many cold days in vegas, so it dont bug me that much.
