belvedere exhaust manifolds #67921
06/05/08 02:58 AM
06/05/08 02:58 AM
south carolina
gastongremlin Offline OP
south carolina
i have a 1964 belvedere that i hope to drop a 440 in later this summer. i'm trying to get parts and info together before i start. i was wondering if someone could tell me the pn# for the correct big block exhaust manifolds. it's not a by the numbers restoration but i do want it to look good and have the best clearance possible.
Re: belvedere exhaust manifolds [Re: gastongremlin] #67922
06/05/08 09:46 AM
06/05/08 09:46 AM
Austin, Texas
65Sat440 Offline
65Sat440  Offline
Austin, Texas
You should check out MyMopar for lots of good part# info. It shows right side HP manifold to be #2806900 and left side, e.g. a 67 440, as #2806974.
Good luck with the project.
Re: belvedere exhaust manifolds [Re: 65Sat440] #67923
06/05/08 10:52 AM
06/05/08 10:52 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
unless you use 413 or 426 manifolds no guarnetee they will fit.
Re: belvedere exhaust manifolds [Re: 05dakota] #67924
06/05/08 11:15 AM
06/05/08 11:15 AM
south carolina
south carolina
a 440 may not have been available but the other big blocks were. thanks for the info from MyMopar.Com.
Re: belvedere exhaust manifolds [Re: gastongremlin] #67925
06/05/08 02:13 PM
06/05/08 02:13 PM
6T4 Polara Offline
6T4 Polara  Offline
My 64 Dodge engine in original location the passenger side is tight and requires jacking engine up to install HP manifolds.
JOhn
Re: belvedere exhaust manifolds [Re: gastongremlin] #67926
06/06/08 11:07 PM
06/06/08 11:07 PM
south carolina
south carolina
currently the car has plain jane 426 with ram charger manifolds. later on i plan to reinstall the original 4 speed set up. with the ram charger manifolds, it appears they will be in the way of some of the linkage. the car came from the factory with a 426 but not this one.
